Projections from Tubular Neighborhoods
  • Context: Graduate
  • Thread starter Thread starter Goklayeh
    Projections
The discussion focuses on proving that the retraction function r(y) minimizes the distance from points in a smooth, compact embedded submanifold M within a tubular neighborhood U in ℝⁿ. The tubular neighborhood is defined using a diffeomorphism E from the normal bundle NM, specifically for vectors v with |v| < δ. The user successfully demonstrated that if y ∈ ℝⁿ has a closest point x ∈ M, then the vector y - x lies in the normal space N_x M, and through the analysis of a curve γ connecting x and another point p in M, they established that the minimum occurs at y = r(y).
  • Understanding of smooth manifolds and submanifolds
  • Familiarity with tubular neighborhoods in differential geometry
  • Knowledge of retraction mappings and projections in vector spaces
  • Basic concepts of convex functions and their properties
  • Study the properties of tubular neighborhoods in differential geometry
  • Explore the concept of retraction mappings in smooth manifolds
  • Learn about the normal bundle and its applications in geometry
  • Investigate convex functions and their role in optimization problems
Mathematicians, particularly those specializing in differential geometry, as well as graduate students studying manifold theory and optimization in geometric contexts.
Goklayeh
Hello! Could anybody give me some hint with the following problem? Consider a smooth, compact embedded submanifold [itex]M = M^m\subset \mathbb{R}^n[/itex], and consider a tubular neighborhood [itex]U = E(V)\supset M[/itex], where [itex]E: (x, v) \in NM \mapsto x + v \in M[/itex] is a diffeomorphism from a open subset of the normal bundle [itex]NM[/itex] of the form [itex]V = \left\{(x, v) \in NM \: : \: \left| v \right| < \delta\right\}[/itex]. We know that [itex]r:=\pi \circ E^{-1}[/itex] is a smooth retraction, where [itex]\pi:(x, v) \in NM \mapsto x \in M[/itex] is the projection. How can I prove that if [itex]y \in U[/itex], where [itex]U[/itex] is a sufficiently small tubular neighborhood, then [itex]r(y)[/itex] realizes the minimum of the distance from the points of [itex]M[/itex]? I just proved, following Lee's hints, that if [itex]y \in \mathbb{R}^n[/itex] has a closest point [itex]x \in M[/itex], then [itex]y - x \in N_x M[/itex], but I can't realize how to use this information!
Maybe, I've solved: let [itex]y = x + v[/itex], for some [itex](x, v) \in V[/itex], and consider any other point [itex]p \in M[/itex], together with a curve [itex]\gamma: (-\epsilon, \epsilon) \to M[/itex] such that [itex]\gamma(0) = x, \dot{\gamma}(0) = v[/itex] joining [itex]x, p[/itex]. Without loss of generality, [itex]y = 0[/itex]. If [itex]f(t):=\frac{1}{2}\left|\gamma(t)\right|^2[/itex], then
[tex]\dot{f}(0) = \left<\gamma(0), \dot{\gamma}(0)\right> = \left<x, v\right> = 0[/tex]
since [itex]y - r(y) = x + v - x = v \in N_x M[/itex]. Since [itex]f[/itex] is convex, [itex]0[/itex] is a minimum, hence the thesis for the arbitrariness of the curve [itex]\gamma[/itex]. Am I wrong?
  • · Replies 0 ·
  • · Replies 20 ·
