Proof 30 divides ab(a^2 -b^2)(a^2 +b^2)
  • Thread starter Thread starter eaglemath15
    Proof
The discussion centers on proving that the expression ab(a² - b²)(a² + b²) is divisible by 30 for all integers a and b, under the condition that a ≠ b. Participants emphasize the necessity of demonstrating divisibility by the prime factors 2, 3, and 5. They suggest using modular arithmetic to simplify the proof, particularly by checking pairs of values of a and b modulo 5, 3, and 2. The consensus is that a thorough examination of these factors will confirm the divisibility of the original expression.
  • Understanding of modular arithmetic
  • Familiarity with prime factorization
  • Basic algebraic manipulation skills
  • Knowledge of divisibility rules for integers
  • Research modular arithmetic techniques for proving divisibility
  • Study the properties of prime numbers and their role in factorization
  • Learn about exhaustive proof methods in number theory
  • Explore examples of divisibility proofs involving multiple factors
Mathematics students, educators, and anyone interested in number theory and proofs of divisibility, particularly in the context of integer algebra.
eaglemath15
I was given the assignment
"Show that for all integers a and b, ab(a^2 -b^2)(a^2 +b^2) is divisible by 30."
Now, I am aware that this fails if a=b, but I want to try to prove this if we assume a≠b.
I've reduced it to the equation (a^5)b-a(b^5), which works, and I know that I could pick the smallest two integers (1 and 2) and show that, but I don't know how to show that it exists for every integer. Should I do proof by contradiction?
No, if a = b, the expression above is 0, which is divisible by 30. Note that 0/30 = 0.
a5b - ab5 is NOT an equation.
What do you mean by "works"? All you have done is to write the original product of three factors as the difference of two terms.
Clearly ab(a2 - b2)(a2 + b2) = a5b - ab5, but I don't see how this is a step in the forward direction.
For an expression to be divisible by 30, it has to be divisible by 2, 3, and 5.
Yea, reducing it to a^{5}b-ab^{5} is actually unhelpful as far as I can see, given how I proved it, as it would make things more complicated.. You want to do as Mark said and consider whether or not it is divisible by 2, 3, and 5. If it is divisible by anyone of them, you don't have to worry about the factors you used affecting divisibility by the others since 2,3,5 are prime and therefore relatively prime. So just show that each of those numbers must divide the original equation and you are done.
Right. Actually the more you factor it the easier it is. There an exhaustive way to check this if you aren't feeling particularly inspired. For example, to check if it's divisible by 5, check all pairs of values of a and b mod 5. There are 25 pairs. Using a form of symmetry will cut that in half. a=b mod 5 obviously works. Now there aren't that many pairs left. The mod 3 and mod 2 cases are much easier.
The reason I had done this was not with respect to the proof, but because it made it easier for me to test whether or not this is actually divisible by 30 (my professor wants us to be in the habit of testing things and not just taking his word that they are true). Thank you for your help though.
Ah I see, good 'ol testing things (but hopefully not "proving" them via American Induction, as my math prof used to joke about).
An exhaustive test of a finite number of cases is a rigorous proof. You could have done this by doing the whole problem that way. But mod 30 you start with 900 cases. The factorization 30=2*3*5 makes it much easier.
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 40 ·
