Proof for 2^n ≥ n + 5 for n > 5 using mathematical induction
  • Thread starter Thread starter iamsmooth
    Inequality Proof
The discussion centers on proving the inequality 2n ≥ n + 5 for all integers n > 5 using mathematical induction. The proof consists of a basis step confirming the inequality for n = 3 and an inductive step assuming the inequality holds for k and proving it for k + 1. The proof is validated with the condition that k must be greater than or equal to 3, thus establishing the inequality for all integers greater than 5. The discussion concludes with suggestions for improving clarity in the proof presentation.
  • Understanding of mathematical induction
  • Familiarity with inequalities
  • Basic knowledge of exponential functions
  • Ability to manipulate algebraic expressions
  • Study the principles of mathematical induction in depth
  • Learn how to structure mathematical proofs clearly
  • Explore advanced topics in inequalities and their applications
  • Practice proving inequalities using various methods
Students studying mathematics, particularly those focusing on proofs, educators teaching mathematical induction, and anyone looking to enhance their proof-writing skills.
iamsmooth
Prove that:
2^n \geq n + 5 for all integer n > 5
n/a
This is what I did, just want to see if it's right.
Using mathematical induction:
Basis step:
When n = 3,
2^3 \geq 3 + 5
Since 8 = 8, base case is proven
Inductive step:
Assume 2^k \geq k + 5 for all integers k greater or equal to n.
We want to prove that 2^{k+1} \geq k + 1 + 5
Using our assumption, 2^k \geq k + 5, I know that:
2(2^k) \geq 2(k + 5)
=2^{k+1} \geq 2k + 10
From here, if I can prove 2k+10 is greater or equal to k+6, then it will prove
2^{k+1} \geq k + 6
So:
2k+10 \geq k + 6
2k \geq k - 4
k \geq -4
Thus is proven because k was said to be greater or equal to n which is at least 3. So the inequality is true.
Since inductive step is proven, 2^3 \geq 3 + 5 must be true.
QEDDoes this proof stand? I haven't had much practice with inequalities... so I'm very unsure about this proof.
Thanks.
Your reasoning is fine, but you should clean up your proof a bit. If you were told to prove the inequality for n > 5, and it evidently holds for n greater than or equal to 3, then the first thing you should do is state that this latter claim is the claim you are going to prove (even though it is a slightly "stronger" or better claim) by induction.
Under this claim, your base case is fine. For your inductive step, you should stick to one letter. If you are going to use k instead of n, which is fine since you are already given an n in the problem statement, then you actually need to say that the statement holds for k. This means that the inductive step is
Assume 2^k \geq k + 5 for all integers k \geq 3
(It doesn't matter whether you use k or n or some other letter to denote the natural number that you will increment, but referring to multiple letters in your proof might cause slight confusion)
Besides this, there is nothing wrong with the proof, except at the very end, you should state that the statement you proved is true, not just its base case (this may be a typo).
Yeah, that last bit was a typo. I'll post future proofs on here to see if I'm improving. Thanks for the tips, appreciate it.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
