Proof of Inequality: Induction & Derivation Help
12 replies · 2K views
PhysicsRock
Given ##x_1, x_2...x_n## and ##x_i \geq 1##, prove ##\prod_{i=1}^{n} (1+x_i) \geq \frac{2^n}{n+1} \left( 1 + \sum_{i=1}^{n} x_i \right)##.
None.
The assignment says proof by induction is possible, I cannot figure out how this is supposed to work out. Does somebody know the name of this by any chance? Seeing a derivation might help come up with an idea for a proof. Thank you everybody.
Can you think of the steps involved in proving something by induction and list them out? That should help you realize what you have to do.
PhysicsRock said:
Homework Statement:: Given ##x_1, x_2...x_n## and ##x_i \geq 1##, prove ##\prod_{i=1}^{n} (1+x_i) \geq \frac{2^n}{n+1} \left( 1 + \sum_{i=1}^{n} x_i \right)##.
Relevant Equations:: None.
The inductive step looks tricky. What about using some calculus?
PeroK said:
Actually, it doesn't need calculus. I just hacked away algebraically until it cracked!
Yeah, I think I found a proof too. Purely algebraically.
PeroK said:
Using induction?
Partly, yes. I first ignored the ##\frac{2^n}{N+1}## and then showed that it fulfills the requirement for the inequality to hold.
PeroK said:
I might post my solution when I get on my laptop later.
Would be nice to see an alternative. Always like to see different proofs, so it would be highly appreciated :)
To take the inductive step, we have to show that for all ##x_1, \dots x_{n+1} \ge 1##:
$$\prod_{i = 1}^{n+1} (1 + x_i) \ge \frac{2^{n+1}}{n+2}\big ( 1 + \sum_{i = 1}^{n+1} x_i \big )$$Given the inductive hypothesis that this inequality holds for all ##x_1, \dots x_{n} \ge 1##. Using this, we have:
$$\prod_{i = 1}^{n+1} (1 + x_i) \ge (1 + x_{n+1}) \frac{2^n}{n+1}\big ( 1 + \sum_{i = 1}^{n} x_i \big )$$We let ##x = x_{n+1}## and ##S = \sum_{i = 1}^{n} x_i##. Note that ##x \ge 1## and ##S \ge n##. Then it is enough to show (this is a standard phrase in proofs) that:
$$(1 + x)\frac{2^n}{n+1}\big ( 1 + S \big ) \ge \frac{2^{n+1}}{n+2}\big ( 1 + x + S \big )$$Or:
$$(n+2)(1 +x)(1 + S) - 2(n + 1)(1 + x + S) \ge 0$$Or:
$$x\big [(n+2)S - n\big ] - n(1 + S) \ge 0$$Finally, as ##x \ge 1##:
$$x\big [(n+2)S - n\big ] - n(1 + S) \ge (n+2)S - n - n(1+S) = 2(S - n) \ge 0$$QED
Note that equality holds if and only if ##\forall i: x_i = 1##.
Reply
PS On a technical note, we could now turn this round and starting with ##S \ge 1## do a sequence of implications from bottom to top. But, I think it's perhaps better to leave it as a sequence of reverse implications or "enough to shows".
