Proof of lim(1/x) x->0 by negating epsilon delta definition of limit
The limit of the function \(\frac{1}{x}\) as \(x\) approaches 0 does not exist, as established by negating the epsilon-delta definition of limits. The correct formulation states that for any \(\epsilon > 0\), there exists a \(\delta > 0\) such that for all \(x\) satisfying \(0 < |x| < \delta\), the inequality \(|\frac{1}{x} - L| > \epsilon\) holds true for any \(L\). The discussion emphasizes the necessity of modifying the definition to account for limits involving infinite quantities, leading to the conclusion that the limit does not exist when \(f(x) = \frac{1}{x}\).
  • Epsilon-delta definition of limits
  • Understanding of limits involving infinite quantities
  • Basic algebra and inequalities
  • Familiarity with functions approaching infinity
  • Study the epsilon-delta definition of limits in detail
  • Explore limits involving infinity and their implications
  • Learn about the behavior of rational functions near vertical asymptotes
  • Investigate the concept of limits in different mathematical contexts
Students of calculus, mathematics educators, and anyone interested in understanding the nuances of limits and their definitions, particularly in the context of functions approaching infinity.
can93
I want to show that \lim_{x \rightarrow 0}\frac{1}{x} does not exist by negating epsilon-delta definition of limit.
We say limit exists when:
\forall \epsilon &gt; 0, \exists \delta &gt; 0 : \forall x(0&lt; \left| x\right| &lt; \delta \Rightarrow \left| \frac{1}{x} - L \right| &lt; \epsilon)
And limit does not exist corresponds to:
\exists \epsilon &gt; 0, \forall \delta &gt; 0 : \exists x(0&lt; \left| x\right| &lt; \delta \wedge \left| \frac{1}{x} - L \right| &gt; \epsilon) (for any L ?)
We look for an \epsilon such that
then using triangle inequality,
\left| \frac{1}{x}\right| + \left| L \right| ≥ \left| \frac{1}{x} - L \right| &gt; \epsilon
therefore
\left| \frac{1}{x}\right| + \left| L \right| &gt; \epsilon
and
| \frac{1}{x}| &gt; \epsilon - \left| L \right|
for \epsilon &gt; |L|, ( the other possibility gives no info since |x| > 0 already)
|x| &lt; \frac{1}{\epsilon - |L|}
we also had
0&lt;|x|&lt;\delta
hence,
|x| &lt; min( \delta , \frac{1}{\epsilon - |L|} )
we found such x satisfies the above condition, for some epsilon and L.
Is that approach correct?? Especially, I am not really sure about the negation of the definition...
Ah now you have to make some alterations to the definition for it to work properly. You have a limit involving an infinite quantity which requires a change in your definition to be :
\forall ε&gt;0, \exists δ&gt;0 | 0&lt;|x-a|&lt;δ \Rightarrow f(x)&gt;ε
So for f(x) = 1/x, you desire a δ which ensures that f will be bigger than epsilon no matter what. You can start finding this delta by massaging the expression f(x) > ε to suit your needs.
alright,
for limits not dealing with infinity, is my negation correct??
can93 said:
alright,
I'm not sure why you would want to negate the statement because |f(x)-L| which translates into |f(x)-∞| is for lack of better term, a garbage statement.
That's why I suggested using the modified form of the definition so it at least makes sense.
To answer your question though, I don't see a problem with your negation.
  • · Replies 31 ·
