When is the minimum polynomial of a scalar matrix kI equal to t-k?
A scalar matrix A is defined as kI if and only if its minimum polynomial is m(t) = t-k. To prove this, one must show two implications: first, that if A = kI, then (t-k)(A) = 0, confirming m(t) as minimal; second, that if m(t) = t-k, then A must equal kI since m(A) = A - kI results in the zero matrix. The discussion emphasizes the importance of understanding the definitions of matrices and polynomials to avoid confusion with terms like f and g. Clarity in these concepts is crucial for solving the problem effectively. Understanding these relationships helps in grasping the properties of scalar matrices and their minimal polynomials.
Robb
Show that A is a scalar matrix kI if and only if the minimum polynomial of A is m(t) = t-k
f(A) is monic
f(A) = 0 since A = kI
Next we must show that deg(g) < deg(f)
I guess I'm not sure where g comes from. Is it merely an assumption? I assume g is a polynomial with root A.
And, if deg(g) < deg(f) then deg(g) must be 0 because deg(f) is 1 so g must be a constant. I think I'm just having trouble wrapping my mind around g. Please advise.
Neither am I. You throw in polynomials ##f(t)## and ##g(t)## without having expalined / defined them.
What does it mean for ##m(t)=t-k## being the minimal polynomial of ##A\,##?
We have two directions to prove, which you should clearly separate:
a) Given ##A=k\cdot I \,\Longrightarrow\, (t-k)(A) = 0\text{ minimal }##
b) Given ##m(t)=t-k \text{ minimal polynomial of }A \,\Longrightarrow \, A= k \cdot I##
On the one hand, if you observe ##m(A) = A - k\cdot I ##, this yields the zero matrix because of the assumption. So the minimal polynomial of ## A## must be ##t-k ##, there are no lower degree polynomials that could possibly work. Constants are not suitable.
Conversely, if ##t-k ## is the minimal polynomial of ##A ##, then by definition ##A - k\cdot I = 0 ##.
Word of advice. Always start from the definitions. Make sure you understand key concepts in this problem: matrices, (minimal) polynomials, root(s) of a polynomial. That way there will be no mysterious symbols ##f## and ## g## appearing out of nowhere.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
