Is the statement 0! = 1 actually wrong or just ill-defined?
  • Context: High School
  • Thread starter Thread starter johncena
    Proof
The discussion revolves around the statement 0! = 1, exploring its proof, definitions, and implications in mathematics. Participants examine the factorial function, its recursive definition, and the reasoning behind defining 0! as 1, including its applications in combinatorics.
  • Meta-discussion
  • Some participants seek a proof for the statement 0! = 1, questioning its validity.
  • Others assert that 0! = 1 is true by definition, referencing the recursive definition of factorial.
  • A participant highlights the role of parity, arguing that since 0 is even and 1 is odd, they cannot be equal.
  • One participant provides a combinatorial interpretation, suggesting that defining 0! as 1 aligns with the concept of choosing 0 elements from a set.
  • There is a discussion about the nature of definitions, with some arguing that definitions cannot be wrong, while others suggest that they can be considered useless or inconsistent.
  • A later reply introduces the idea that the terms "wrong" and "incorrect" can have nuanced meanings in the context of definitions.
Participants generally agree that 0! = 1 is a definition, but there is disagreement regarding the implications of this definition and whether it can be considered wrong or ill-defined. The discussion remains unresolved regarding the nature of definitions and their correctness.
Some participants express uncertainty about the implications of defining 0! = 1, particularly in relation to the consistency of mathematical definitions and axioms.
johncena
what is the proof for the statement 0! = 1??
Mathematics news on Phys.org
a number neither odd nor even cannot be equal to an odd number.
But zero is an even number since it has a parity of 0.
Assuming you mean the factorial of 0, then factorial is usually defined recursively by,
0! = 1
n! = (n-1)! * n for n > 0
So it's true by the definition of the factorial. If you mean why 0 doesn't equal 1 then you have to state explicitly some formal properties of the integers. For instance a popular way to describe the non-negative integers is the Peano Axioms which among other things state that 0 is a non-negative integer, there is no natural number whose successor is 0 and 1 is defined as the successor to 0. Hence if 0 = 1 then 0 would be the successor to 0 which contradicts the axiom that 0 isn't the successor of any non-negative number.
Alternatively if you are allowed to use properties like parity, and the fact that 0 and 1 have different parity, then they can't be equal because parity is uniquely determined. Note: 0 has even parity while 1 has odd parity; 0 is NOT neither odd nor even.
you said n! = (n-1)! * n for n > 0
so taking n = 1,
1! = (1-1)! * 1 = 1
0! * 1 = 1
thus, 0! = 1/1 = 1
is this proof correct?
There is no proof, it's by definition. It gives a basis for a recursive definition of n! as n! = n*(n-1)! and 0! = 1.
Like others said, this is by definition. You might be interested in the http://en.wikipedia.org/wiki/Gamma_function" .
I'll also note a definition can never be wrong. It may be useless, but it's never wrong.
A motivation(maybe) behind defining 0!=1, might be if we look at the combinations of class k taken from a set of n elements.
C_{k}^{n}
THen, since this is nothing else but the set of all subsets of k elements taken from a set of n elements, if we have:
C_0^n=\frac{n!}{(n-0)!0!} then since there is only one set that contains 0 elements taken from any set of n elements (the empty set), it follows that
C_0^n should equal 1, for this to happen 0! should be 1.
... unless a useless definition is defined to be something that is incorrect or wrong. :-p
But that would be a useless definition!
A definition cannot be incorrect or wrong. What a group of definitions can be is inconsistent, which is subtly different :) Determining if a set of axioms is consistent is a difficult problem (and consistency is the cornerstone for godel's theorem as with an inconsistent set of axioms you can prove stupid things like 0=1, 1=2, etc)
I was kinda playing. But what I think is more subtle is the use of the words "wrong" and "incorrect." If one were trying to make a definition of something containing the essence of an idea, such as curvature, then I could see how some definitions can be considered wrong or incorrect. Something being ill-defined often carries connotations of incorrectness or inconsistency, as its name implies. However, stating that the truth/validity in the defining of definition X is false is something I find somewhat meaningless.
  • · Replies 66 ·
  • · Replies 55 ·
  • · Replies 19 ·
