Proof that given function is convex
9 replies · 2K views
PhDeezNutz
Given ##f: \mathbb{R}^n \rightarrow \mathbb{R}## where ##f\left(\vec{x}\right) = \| \vec{x} \|^2## prove that ##f## is convex
Definition of convex function
A function ##f: \mathcal{C} \subset \mathbb{R}^n \rightarrow \mathbb{R}## is convex on convex set ##\mathcal{C}## if ## \forall \vec{x}, \vec{y} \in \mathcal{C}##
##f\left(\left( 1 - \lambda \right) \vec{x} + \lambda \vec{y} \right) \leq \left( 1 - \lambda \right) f \left(\vec{x} \right) + \lambda f \left( y \right)##
where ##\lambda \in \left[ 0,1 \right]##
Also the triangle inequality
## \left\| \vec{a} + \vec{b} \right\|^2 \leq \left\| \vec{a} \right\|^2 + \left\| \vec{b} \right\|^2##
Part 1
##\left\| \vec{y} \right\|^2 \leq \left\| \vec{y} \right\|^2## and since ##\lambda \in \left[ 0,1 \right] \Rightarrow \lambda^2 \leq \lambda##
So
##\lambda^2 \left\| \vec{y} \right\|^2 \leq \lambda \left\| \vec{y} \right\|^2 ##
Part 2
##\left\| \vec{x} \right\|^2 \leq \left\| \vec{x} \right\|^2## and since ##\lambda \in \left[ 0,1 \right] ## we have ##1 - \lambda \leq 1 \Rightarrow \left( 1 - \lambda \right)^2 \leq \left( 1 - \lambda \right)##
So
##\left( 1 - \lambda \right)^2 \left\| \vec{x} \right\|^2 \leq \left(1 - \lambda \right) \left\| \vec{x} \right\|^2##
Part 3 (adding Parts 1 and 2)
##\left( 1 -\lambda \right)^2 \left\| \vec{x} \right\|^2 + \lambda^2 \left\| \vec{y} \right\|^2 \leq \left( 1 - \lambda \right) \left\| \vec{x} \right\|^2 + \lambda \left\| \vec{y} \right\|^2##
Part 4 (Invoking the triangle inequality)
##\left\| \left(1 - \lambda \right) \vec{x} + \lambda \vec{y} \right\|^2 \leq \left( 1 -\lambda \right)^2 \left\| \vec{x} \right\|^2 + \lambda^2 \left\| \vec{y} \right\|^2 \leq \left( 1 - \lambda \right) \left\| \vec{x} \right\|^2 + \lambda \left\| \vec{y} \right\|^2##Taking the first and last part of the above inequality we have
##\left\| \left(1 - \lambda \right) \vec{x} + \lambda \vec{y} \right\|^2 \leq \left( 1 - \lambda \right) \left\| \vec{x} \right\|^2 + \lambda \left\| \vec{y} \right\|^2##
Therefore ##f\left(\vec{x}\right) = \left\| \vec{x} \right\|^2## is convex
Looks okay to me. The steps are all there. Technically, the proof should start with "Let ##\lambda \in [0, 1]## and ##\vec x, \vec y \in \mathbb R^n##" and show explicitly that $$f\left(\left( 1 - \lambda \right) \vec{x} + \lambda \vec{y} \right) \leq \left( 1 - \lambda \right) f \left(\vec{x} \right) + \lambda f \left( \vec y \right)$$
  • Love
You'll have to forgive me I am but a filthy physics major :-p. I'm starting to self [URL='https://www.physicsforums.com/insights/self-study-basic-high-school-mathematics/']study mathematics[/URL] because there were some parts of grad school that seemed extremely hand wavy to me. I'll have to learn proof etiquette.
Thank you for reviewing my proof.
I’m trying to follow this proof of ##x^4## being strictly convex but I don’t understand how they got rid of the cross terms with step ##\left( 2 \right)##
PeroK said:
The cross terms are non-negative.
I’m confused. To me that is precisely the reason we can’t get rid of them in the end. Let me be more explicit.
##\left\| \lambda \vec{x} + \left( 1 - \lambda \right)\vec{y} \right\|^4 = \left( \left\| \lambda \vec{x} \left( 1 - \lambda \right) \vec{y} \right\|^2 \right)^2 \leq \left( \lambda \left\| \vec{x}\right\|^2 + \left(1 - \lambda \right) \left\| \vec{y} \right\|^2 \right)^2##
Where I've used the fact that ##\left\| \vec{x} \right\|^2 ## is convex to get to the ##/leq## inequality
To me the only thing I can do now is "foil it out"
## = \lambda^2 \left\| \vec{x} \right\|^4 + 2 \lambda \left( 1 - \lambda \right) \left\| \vec{x} \right\|^2 \left\| \vec{y} \right\|^2 + \left( 1 - \lambda \right)^2 \left\| \vec{y} \right\|^4##
We know that both ##\lambda , \left(1 - \lambda \right) \lt 1 \Rightarrow \lambda^2 , \left( 1 - \lambda \right)^2 \lt \lambda, 1 - \lambda ##
## \lt \lambda \left\| \vec{x} \right\|^4 + 2 \lambda \left( 1 - \lambda \right) \left\| \vec{x} \right\|^2 \left\| \vec{y} \right\|^2 + \left( 1 - \lambda \right) \left\| \vec{y} \right\|^4##
So all in all
##\left\| \lambda \vec{x} + \left( 1 - \lambda \right) \right\|^4 \lt \lambda \left\| \vec{x} \right\|^4 + 2 \lambda \left( 1 - \lambda \right) \left\| \vec{x} \right\|^2 \left\| \vec{y} \right\|^2 + \left( 1 - \lambda \right) \left\| \vec{y} \right\|^4 ##
Don't know how to get rid of the middle cross term ##2 \lambda \left( 1 - \lambda \right) \left\| \vec{x} \right\|^2 \left\| \vec{y} \right\|^2##
PS It's cometimes easier to generalise things. Suppose ##f: \mathbb R_+ \rightarrow \mathbb R_+## is convex and increasing, then ##f \circ f## is convex and increasing:
Let ##t \in [0, 1]## and ##x, y \in \mathbb R_+##. We have:
$$f(tx + (1-t)y) \le tf(x) + (1-t)f(y) \ \ (\text{as} \ f \ \text{is convex})$$$$\Rightarrow \ f[f(tx + (1-t)y)] \le f[tf(x) + (1-t)f(y)] \ \ (\text{as} \ f \ \text{is increasing})$$ $$\le tf[f(x)] + (1-t)f[f(y)] \ \ (\text{as} \ f \ \text{is convex and} \ f(x), f(y) \in \mathbb R_+)$$$$\therefore f \circ f(tx + (1-t)y) \le tf \circ f(x) + (1-t)f \circ f(y)$$$$\therefore f \circ f \ \text{is convex}$$It's easy to show that ##f \circ f## in increasing, although not a bad exercise, in fact.
  • Love
PeroK said:
You're right. They are simply applying the convex property of ##x^2## twice. There's no expansion needed.
I actually see it now. Wow this has confused me for several days.All we needed to do was make a change of variables
##\left\| \vec{x} \right\|^2 \mapsto X \in \mathbb{R} ##
##\left\| \vec{y} \right\|^2 \mapsto Y \in \mathbb{R} ##
and repeat the argument and replace ##X## and ##Y## at the end.
Can't believe I didn't see it until now. Thank you for your help.
