Proof: Uniformly Continuous Function on a Bounded Set is Bounded
  • Thread starter Quantumpencil
    Proof
2 replies · 3K views · last reply
Quantumpencil
Let f be a real uniformly continuous function on the bounbed set E in R. Prove that f is bounded on E.
Since f is uniformly continuous, [tex]\left|f(x)-f(y)\right|< \epsilon[/tex] if [tex]\left|x-y\right|< \delta[/tex]. Since E is bounded, there exists some maximal distance between x and y; let M be the upper limit and P be the lower limit of E. Then
[tex]\left|x-y\right|< \\left|M-P\right|<[/tex]. If M, P are not in E, then define two sequences {x_n} and {y_n} such that lim n->infinity {x_n}=M and lim n->infinity {y_n} = P.
Then the definition of uniform continuity implies that if we let [tex]\delta = abs(M-P)[/tex], so that abs(x-y) < delta for all x, y then abs(f(x)-f(y))< epsilon for all f(x), f(y), with epsilon equal to lim n->infinity {f(x_n)}=M and lim n->infinity {f(y_n)}
I feel fairly solid about this, but I'm finding the difference between absolute continuity and continuity a bit confusing and would like a rigor/correctness check.
Thanks.
Here's where your proof goes wrong:
Then the definition of uniform continuity implies that if we let LaTeX Code: \\delta = abs(M-P) , so that abs(x-y) < delta for all x, y then abs(f(x)-f(y))< epsilon for all f(x), f(y), with epsilon equal to lim n->infinity {f(x_n)}=M and lim n->infinity {f(y_n)}
You can't just pick a delta like this. You can only pick an epsilon and then prove existence of delta using the definition of uniform continuity. Here's how I would prove it:
Choose arbitrary epsilon > 0. Then there exists delta>0 such that as long as |x-y|<delta, |f(x)-f(y)|<epsilon. Choose N so large that N delta > |M-P|. Now, choose arbitrary x0 in E. Then we must have f(x0) - epsilon N < f(x) < f(x0) + epsilon N for all x in E (check this). This proves the theorem.
Hm, ok. So that is the same idea I think; or at least that makes complete sense and I was just being silly.
Thanks.
