Proofs for limits, feels unfamilar
7 replies · 3K views · last reply
1MileCrash
Firstly, I find the math syntax on this board incredibly difficult to use, so bear with me. Using any symbol makes the text appear on the next line... I don't know if it is my browser, or what, but I tried to make due. Sorry.
Construct an "epsilon minus delta" proof for each limit fact.
limit of x approaching 5 of:
(x^2 - 25) / (x - 5) = 10
Pre-work:
( x^2 - 25 ) / ( x - 5 )
( x + 5 )
0 < |x - 5| < (delta) => | ( x + 5 ) - 10 | < (epsilon)
| ( x - 5 ) | < (epsilon)
Proof:
| ( x^2 -25 ) / ( x - 5 ) | = | x - 5 | < (delta) = (epsilon)
Obviously a very simple problem since the limit statement and function are essentially the same, but I don't remember the exact "content" people are looking for when they want limits proven.
That's exactly what you want. If f(x)=(x^2-25)/(x-5) then if you pick any epsilon and set delta=epsilon then |x-5|<delta implies that |f(x)-10|<epsilon.
Thank you sir, are most professors going to dislike me simplifying the function outside of the "preliminary analysis" most of them call for?
For example:
limit x -> 1 of
( 10x^3 - 26x^2 + 22x - 6 ) / ( x - 1 )^2
f(x) = 10x - 6
Preliminary:
0 < | x - 1 | < delta => | (10x - 6) - 4 | < epsilon
=> | (10x - 10 | < epsilon
=> 10 | x - 1 | < epsilon
=> | x - 1 | < epsilon / 10
Proof:
| ( 10x - 6 ) - 4 | = | 10x - 10 | = 10 | x - 1 | < 10(delta) = epsilon
Can I just treat the problem as if they gave me 10x - 6 from the get-go, or should I show my work for that in the preliminary work? I'm always careful about these things because it's only partially knowing the math.
(10x^3 - 26x^2 + 22x - 6)/(x-1)^2 is the SAME thing as 10x - 6 UNLESS x=1. And if you are evaluating the limit as x->1 you don't care about the value of the function at x=1. Not even a little. If you can convince your professor by stating you understand that the functions aren't the SAME, but they are for the purpose of evaluating the limit, then I really don't think any reasonable person could possibly object.
IMO, you should always show your working, so you should add how you simplified your numerator, as it's not entirely obvious by inspection =)
Sure, sure. You should probably also show you factored (10x^3 - 26x^2 + 22x - 6) to (x-1)^2*(10x-6). Wouldn't hurt for the purposes of the presentation.
Alright guys, I worked on this one for a good 15 minutes today... I don't have my attempt at a solution, it's huge and in my notes, but I got stuck.
lim
x -> 4 f(x) = sqrt(7)
f(x) = [sqrt(2x-1)] / [sqrt(x-3)]
Any takers on this doozie?
What is the question? You seem to have written this reversed: if f(x)= sqrt(2x-1)/sqrt(x-3) then limit as x-> 4 of f(x) is sqrt(7).
But what are you asking? If you are just asking how to show that, since sqrt is a continuous function, this is simply sqrt(2(4)- 1))/sqrt(4- 3)= sqrt(7)/sqrt(1)= sqrt(7).
If you are asking how to prove it from the definition, then you are going to have to look at
[tex]\frac{\sqrt{2x-1}}{\sqrt{x-3}}- \sqrt{7}= \frac{\sqrt{2x-1}- \sqrt{7x- 21}}{\sqrt{x- 3}}[/tex]
and I would recommend multiplying both numerator and denominator by the complement,
[tex]\sqrt{2x-1}+ \sqrt{7x- 21}[/tex]
