Propagation of Error/Uncertainty
  • Thread starter Thread starter luma
    Propagation
The discussion centers on understanding the propagation of error and uncertainty in mathematical functions. A user explores how to calculate uncertainty for a cubic function and questions why the results from their derivative calculations do not align with direct evaluations of the function at adjusted values. They find that using derivatives provides an approximation of error, but this approximation becomes less accurate as the range of input values increases. The conversation emphasizes that while derivatives can estimate uncertainty, they assume a linear behavior around the point of interest, which may not hold true over larger intervals. Ultimately, the discussion highlights the limitations of using derivatives for error estimation in non-linear functions.
luma
I'm trying to get an intuitive sense for errors and picked some random numbers:
x = 2.5 +/- 0.01
find f(x) = x³
d f(x) / dx = 3x²
d f(x) = 3x² dx
= 3(2.5)² 0.01
= 0.1875
What I don't get is why f(x - Δx) ≠ f(x) - 0.1875 and why f(x + Δx) ≠ f(x) + 0.1875
Where did I go wrong in my method for finding the uncertainty value? Thanks
I found a webpage which lists:
Q = a^n \Rightarrow \frac{\Delta Q}{Q} = |n| \frac{\Delta a}{a}
Applying the method I used in OP here,
\frac{\delta Q}{\delta a} = n a^{n-1}\\<br /> \delta Q = na^{n-1}\delta a\\<br /> \therefore \frac{\delta Q}{Q} = \frac{na^{n-1}\delta a}{a^n} = n \frac{\delta a}{a}
So it looks like my method of deriving the uncertainty is correct.
Working out f(x) = x^6; x = 25 +/- 1 I get do,
f(25 - 1) = f(24) = 191102976
f(25 + 1) = f(26) = 308915776
now using the identity df(x) = 6 25^5 * 1 = 58593750
25^6 + 58593750 ≠ (25+1)^6
25^6 - 58593750 ≠ (25-1)^6
Any ideas?
Yes, you can think of a small error as an "differential" and approximate errors in functions of the measurement using the derivatives.
If y= x^2 then dy/dx= 2x so that dy= 2xdx. You could also say, then, that
\frac{dy}{y}= \frac{2xdx}{y}= \frac{2xdx}{x^2}= 2\frac{dx}{x}
so that the "relative error", the actual error in the measurement divided by the measurement, is multiplied by 2.
More generally, if f(x,y)= xy, where x and y are independent measurements, then df= ydx+ xdy and so
\frac{df}{f}= \frac{ydx+ xdy}{xy}= \frac{dx}{x}+ \frac{dy}{y}.
This is equivalent to the old engineering "rule of thumb": "When measurements are added, their errors add, when measurements are multiplied, their relative errors add".
Thank you for your informative post.
But what I still don't get is what they are showing?
If I make a measurement of x = 2 +/- 1 otherwise written as x = [1,3]
Then y = x² would be [1,9]
Using the rule derived dy = y (2 dx / x) = 2 x dx = 2*2*1 = 4
y = 2² +/- 4 = [0,8] ≠ [1,9]
So what does this represent intuitively?
Is this only an approximation? It doesn't look like it should be
Using the derivative is basically a way of saying "We're going to assume our function really looks like a line, and use the slope of that line to figure out what the error is".
The bigger your interval, the more room for error as the tangent line becomes a worse and worse approximation.
Notice that [0,8] is the range of the tangent line at x=2 over the interval[1,3]
Thank you! Of course...
  • · Replies 18 ·
  • · Replies 20 ·
