Finding a Minimum Value for a Continuous Function on a Compact Set
  • Thread starter Thread starter trap101
    Property
The discussion centers on proving that for a continuous function f: S → R defined on a compact set S ⊆ ℝn, where f(x) > 0 for all x in S, there exists a constant c > 0 such that f(x) ≥ c for every x in S. Participants reference the Extreme Value Theorem (EVT), confirming that since S is compact, f achieves its minimum and maximum values. The conclusion is that c, defined as f(a) for some a in S, must be positive, as a negative c would contradict the condition f(x) > 0.
  • Understanding of the Extreme Value Theorem (EVT)
  • Knowledge of compact sets in ℝn
  • Familiarity with continuous functions and their properties
  • Basic concepts of real analysis
  • Study the implications of the Extreme Value Theorem in real analysis
  • Explore properties of continuous functions on compact sets
  • Investigate the relationship between compactness and boundedness in ℝn
  • Learn about the definitions and examples of positive functions in mathematical analysis
Mathematicians, students of real analysis, and anyone studying properties of continuous functions and compact sets will benefit from this discussion.
trap101
Suppose S\subsetℝn is compact, f: S-->R is continous, and f(x)>0 for every x \inS. Show that there is a number c>0 such that f(x) ≥ c for every x\inS.
Attempt:
Since S is contained in Rn is compact, then S is closed and bounded.
By the extreme value thm there exists values a,b that are an absolute minimum and absolute maximum respectively. Let c = f(a). Therefore by EVT f(c) ≤ f(x) in R.Well I have the solution manual and their solution is way different to what I attempted. Is there anything right about this?
Your solution is correct. You might want to explain why c>0 however.
Also, this should be c≤f(x).
But isn't c \in S. SO wouldn't the function map c to f(c)?
Is the fact c having to be positive because if c < 0 ==> f(a) < f(c) ?
You defined c=f(a). So c is an element of f(S)\subseteq \mathbb{R}. Writing f(c) makes no sense.
Again, f(c) makes no sense.
got it now, thanks foe the help.
