What Functions Satisfy f(x)f(-x) = 1?
  • Context: Undergrad
  • Thread starter Thread starter Mr Davis 97
    Property
The discussion centers on identifying functions that satisfy the equation f(x)f(-x) = 1. Key examples include exponential functions such as f(x) = e^x and piecewise functions like f(x) = {2^x for |x|<5, 3^x for |x|≥5}. The conditions for continuity and differentiability are emphasized, with solutions requiring f(0) to be either 1 or -1, and f(x) to be positive or negative for x>0, respectively. Additionally, trivial solutions such as f(x) = 1 and f(x) = -1 are acknowledged.
  • Understanding of real-valued functions and their properties
  • Familiarity with exponential functions and their characteristics
  • Knowledge of continuity and differentiability in mathematical analysis
  • Basic understanding of piecewise functions
  • Explore the properties of exponential functions in depth
  • Research the implications of continuity and differentiability on function behavior
  • Investigate piecewise function construction and applications
  • Learn about differential equations related to function behavior
Mathematicians, students studying real analysis, and anyone interested in functional equations and their properties.
Mr Davis 97
Out of curiosity, I'm trying to find functions of a real variables such that ##f(x)f(-x) = 1##. One obvious example is ##f(x) = e^x##, and all other exponential functions. Are there any other examples? How would I go about generating them?
Mathematics news on Phys.org
You already did. ##f(0)=\pm 1## and there is a differential equation
Freely choose f(x) for x>0 as long as no value is zero. Choose -1 or 1 for f(0). Fix f(x) for negative x according to your equation.
If ##f(x)## has to be continuous, the functions ##f(x) = \exp (x^n )##, where ##n## is an odd integer, are one example of a solution.
Piecewise continuous examples include functions like
##f(x) = \left\{\begin{array}{c} 2^x, \hspace{30pt} |x|<5\\3^x, \hspace{30pt}|x|\geq 5\end{array}\right.##
Ugly, but correct. I was looking for too decent :rolleyes: functions and thought to exploit ##f'(x) f(-x) + f(x) f'(-x) = 0 ## which is satisfied if ##f'(x) = \pm f(x)\ \forall x\ ## and also if ##f'(x) = 0\ \forall x\ ## . But compared to mfb, that's far too limited
If f(x) has to be continuous then we have the options f(0)=1 and f(x)>0 arbitrary but continuous for x>0, or f(0)=-1 and f(x)<0 arbitrary but continuous for x>0. In both cases we can again find the negative function values with the given constraint and it will always be continuous there as well.
If f(x) for x>0 is differentiable and the limit of the derivative for x->0 is finite then I would expect f(x) to be differentiable everywhere.
This works both for real and complex function values.
f(x)=x^{2n}, f(x)=\lvert x \rvert, f(x)= \cos(\pi x),...
Huh ?
mfb said:
You might want to check that @Svein.
Sorry, did not read the specs closely enough (read it as f(1)f(-1)=1).
But then the constant function f(x)=1 is a trivial solution.
Right. It is a special case of ##f(x)=k^x## which was mentioned in post #1 ("all exponential functions").
Even the function ##f(x) = |x|^x## is a solution if value ##f(x) = 1## is assumed at ##x=0## where it is undefined.
Another trivial solution is f(x)=-1...
  • · Replies 20 ·
  • · Replies 17 ·
