Proportion of energy gained by decay products
  • Context: Graduate
  • Thread starter Thread starter Punch
    Decay Energy
The discussion centers on the proportion of energy gained by decay products during alpha decay, specifically focusing on the energy distribution between the decay products, uranium-235 and helium-4, when a total decay energy of 10 MeV is assumed.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant inquires about the proportion of energy gained by decay products during alpha decay.
  • Another participant notes that the energy gained depends on the decay energy and emphasizes the conservation of momentum, mentioning that a more massive parent nucleus results in less recoil.
  • A third participant clarifies that they understand the dependence on the mass of the parent nucleus but seeks a method to determine the specific proportion of the 10 MeV gained by uranium-235 and helium-4 as kinetic energy.
  • A later reply suggests using conservation of energy and momentum to derive the kinetic energies of the decay products, providing equations for calculating the energies based on momentum.
Participants do not reach a consensus on the specific method for determining the energy proportions, and multiple approaches are discussed without resolution.
The discussion involves assumptions about the decay energy and the masses of the decay products, which may affect the calculations and conclusions drawn.
Punch
What is the proportion of energy gained by the decay products when a nuclei undergoes alpha decay?
It depends upon the decay energy. Energy is conserved, but so is momentum, so the parent nucleus experiences some recoil. The more massive the parent nuclues, the less the recoil (relative to the momentum of he alpha, that is).
Hello! Thank you for your reply. Sorry, you may have misunderstood my question.
I understand that the amount of energy gained by the decay products depends on how massive the parent nucleus is.
However, my question is: Assuming that we a total of 10MeV to be gained by decay products, 235-Uranium and 4-Helium as KE, how do we determine the proportion of the 10MeV gained by each decay product.
Use the conservation of energy and momentum: In the rest frame of the plutonium nucleus, both U and alpha will get the same momentum magnitude p. Their kinetic energies are then given by [itex]E_{uranium}=\frac{p^2}{2\cdot 235amu}[/itex] and [itex]E_{alpha}=\frac{p^2}{2\cdot 4amu}[/itex]. The sum has to be 10 MeV, solve this for p and plug in the equations again to get the energies for both decay products. You can use the true masses instead of the 235amu and 4amu approximations here if you like, but it will not change to result much.
  • · Replies 32 ·
