Protons + Neutrons + Electrons =?
The discussion centers on the interactions between protons, neutrons, and electrons when beams of these particles are shot next to each other. It is established that protons and electrons attract each other, potentially leading to the formation of atoms if the beams are sufficiently close and energetic. Neutrons, which do not carry an electrical charge, primarily interact through strong forces and can influence the behavior of protons. The complexity of these interactions, including the possibility of particle production and the challenges of three-body scattering processes, is highlighted.
  • Understanding of particle physics concepts, including protons, neutrons, and electrons.
  • Familiarity with atomic structure and the formation of atoms.
  • Knowledge of strong interactions and their role in particle behavior.
  • Basic grasp of quantum mechanics, particularly regarding particle interactions.
  • Research the principles of particle beam interactions in high-energy physics experiments.
  • Learn about the process of beta decay and its implications for particle transformation.
  • Explore the concept of strong force interactions and pion exchange between nucleons.
  • Investigate the challenges of three-body scattering processes in quantum mechanics.
Physicists, students of particle physics, and anyone interested in the fundamental interactions between subatomic particles will benefit from this discussion.
Dominisi
This question has been boggling my mind for some time, hopefully some of you can shed some light on the subject. What would happen if one were to shoot a beam of Protons, a beam of neutrons, and a beam of electrons next to each other? I've made a little diagram below to kind of explain what I'm talking about.
Electrons ----------------------------------------------------
Neutrons -----------------------------------------------------
Protons ------------------------------------------------------
Thanks for the help..
Why do you expect something special to happen? The question seems a bit random so maby I don't quite understand your idea?
The electrons and protons would attract each other if they are close enough so the lines would maby converge. The neutrons would continue straight ahead unless they collide with the converging protons.
The electrons and protons will attact one another but as the electrons are much lighter, they will move most of the distance. Therefore, the protons will still have a relatively streight path of movement
And what would be the final result? Would you get atoms?
I all depends on how close the beams are and how energetic they are: extremely close beams might produce atoms -- nucleii+elctrons -- generally speaking, the interactions between the three particles are very complex: neutrons have electrical properties, like magnetic moments, neutrons and protons interact primarily through the strong interactions -- like pion exchange -- which can be attractive or negative depending on the spin states -- so the possibiities are endless, including the production of other particles as well as photons. It's also well known to theorists that solving the three body scattering process is at best extraordinarily difficult. If you specify the details of your proposed experiment, energy, location of wave packets, spin states,and so forth, you could make some progress, maybe.
Regards,
reilly Atkinson
Im not too sure on this but if a proton and a electron combine, do they become a neutron like the opposite of beta decay? if so, the result would be two neutron streams which, if close enough will combine into one due to their gravitational pull on one another.
Yes, an electron and a proton can combine to form a neutron and a neutrino, but not very often -- low,low probability. I suspect that the probability is much higher for an electron and a proton to form a hydrogen atom. The devil is in the details.
Regards,
Reilly Atkinson
  • · Replies 20 ·
