Prove All Numbers Equal: No 0 Needed!
  • Level: Undergrad
  • Thread starter amits
    Numbers
8 replies · 5K views · last reply
amits
All numbers are equal :D
heres the latest proof and it doesn't involve 0 anywhere. no term like (a-b) is involved unlike other similar proofs
-ab = -ab
=> a^2 - a^2 - ab = b^2 - b^2 - ab
=> a^2 - a(a+b) = b^2 - b(a+b)
=> a^2 - a(a+b) + (a+b)^2/4 = b^2 - b(a+b) + (a+b)^2/4
as (x-y)^2 = x^2 - 2xy + y^2,
[a - (a+b)/2]^2 = [b - (a+b)/2]^2
taking square roots,
a - (a+b)/2 = b - (a+b)/2
a = b
hence proved :D
now with all numbers having been proved equal without involving "0" anywhere, what's the need to study anything :D
just noticed, this is my 1st post here after 7 years :o
You can't take square roots. x^2 = y^2 does not imply x = y
If it did, this would have been your 7th post after 1 year.
Your second line contains an error. You added a^2 - a^2 to one side of the equation, but b^2 - b^2 to the other side. The only way for this to leave the equality unchanged is for a to equal b... so it's no surprise that you find out later that a = b.
- Warren
This is the same as
a^2 + b^2 - ab = b^2 + a^2 - ab , which don't think should create any problems.
This is your error. Taking square roots leads to
a-(a+b)/2=b-(a+b)/2
or
a-(a+b)/2=-(b-(a+b)/2)
The former yields a=b. The latter yields a+b=a+b.
- Warren
That step is correct. It's just adding zero to each side.
- Warren
it isn't an error. i added a^2 + b^2 to both sides
-ab = -ab
a^2 + b^2 - ab = a^2 + b^2 - ab
also a^2 - a^2 = 0 & b^2 - b^2 = 0, so adding that doesn't make a difference
yes, you are right. a number always has 2 square roots, 1 positive & 1 negative
You got it wrong.
2^2 = (-2)^2
when you have sqr root you have to have either + or - sign. you only considered + sign. Consider - sign and you will get a+b = a+b
