Prove an equation involving inverse circular functions
6 replies · 2K views
brotherbobby
If ##\sin^{-1}x+\sin^{-1}y+\sin^{-1}z=\pi##, show that ##\boxed{x\sqrt{1-x^2}+y\sqrt{1-y^2}+z\sqrt{1-z^2}=2xyz}##
1. ##\sin^{-1}x+\sin^{-1}y = \sin^{-1}(x\sqrt{1-y^2}+y\sqrt{1-x^2})##
2. ##\sin^{-1}0=\pi##
(I must confess that, in spite of working through the chapter on inverse circular functions, I could barely proceed with this problem. Note what it asks to prove : ##x\sqrt{1-x^2}+\ldots## and how much is that at odds with the formula (1 above) of adding two ##sin^{-1}##'s, where you have ##x\sqrt{1-y^2}+\ldots##)
Attempt : From the given equation, ##\sin^{-1}x+\sin^{-1}y+\sin^{-1}z=\pi\Rightarrow \sin^{-1}(x\sqrt{1-y^2}+y\sqrt{1-x^2})=\sin^{-1}0-\sin^{-1}z##, which simplifies to##\\[10pt]##
##\sin^{-1}(x\sqrt{1-y^2}+y\sqrt{1-x^2}) = \sin^{-1}(0\sqrt{1-z^2}-z\sqrt{1-0^2})=\sin^{-1}(-z)\Rightarrow \small{x\sqrt{1-y^2}+y\sqrt{1-x^2} = -z}## ##\\[10 pt]##
Upon squaring both sides, we obtain ##x^2(1-y^2)+y^2(1-x^2)+2xy\sqrt{(1-x^2)(1-y^2)}=z^2##.
This is clearly looking hopeless far as the required solution (in box above) is concerned.
Any help or hint will be welcome.
Whenever you see a function of ## 1 - x^2 ## this should alert you that a trigonometric substitution may be useful and from the first equation ## x = \sin \alpha ## etc. looks promising...
brotherbobby said:
Homework Statement:: If ##\sin^{-1}x+\sin^{-1}y+\sin^{-1}z=\pi##, show that ##\boxed{x\sqrt{1-x^2}+y\sqrt{1-y^2}+z\sqrt{1-z^2}=2xyz}##
Relevant Equations:: 1. ##\sin^{-1}x+\sin^{-1}y = \sin^{-1}(x\sqrt{1-y^2}+y\sqrt{1-x^2})##
Do you have additional context, i.e., are x,y,z any 3 Real numbers, etc.?
I think we can start by assuming that ## x, y, z \in [0, 1] ## and then see if any loosening of this makes sense.
Does ## \alpha + \beta + \gamma = \pi ## remind you of a geometrical figure?
Hi, I am the creator of this thread or OP as you call them on here in PP.
I do not understand. We know that ##-1\le \sin\theta \le 1##, so if ##\sin\theta=x\Rightarrow \theta=\sin^{-1}x##, of course we must have ##-1\le x \le 1##.
Please correct me if I am making a silly mistake somewhere.
No you are right, but this is not really an important point. Have you tried the ## x = \sin \alpha ## substitution yet?
Yes. I am the creator of this thread. Let me mention the problem statement and solution.
Problem statement :
If we have ##\boldsymbol{\sin^{-1}x+\sin^{-1}y+\sin^{-1}z=\pi}##, show that ##\boxed{x\sqrt{1-x^2}+y\sqrt{1-y^2}+z\sqrt{1-z^2}=2xyz}##.
Revised attempt : As mentioned by @pbuk above, let me take the L.H.S. of what is asked to be proven in blue colour above and substitute in it the variables ##x=\sin\alpha, y = \sin\beta\; \text{and}\; z = \sin\gamma##. That would make the given problem statement in bold italicised characters above as :
\begin{equation}
\alpha+\beta+\gamma=\pi
\end{equation}
The L.H.S. of the required statement becomes= ##\sin\alpha \cos\alpha+\sin\beta \cos\beta+\sin\gamma \cos\gamma = \dfrac{1}{2}(\sin 2\alpha+\sin 2\beta+\sin 2\gamma) ## ##\\[10 pt]##
##=\dfrac{1}{2}\left[2\sin(\alpha+\beta)\cos(\alpha-\beta)+2\sin\gamma \cos\gamma \right]\;\;\;\;## (using ##\sin(C+D)## rule and ##\sin 2A## rule) ##\\[5pt]##
##=\sin\gamma \cos(\alpha-\beta)+\sin\gamma \cos\gamma\;\;\;\;##(since ##\alpha+\beta=\pi-\gamma##)
##=\sin\gamma[\cos(\alpha-\beta)+\cos\gamma]=z . 2 \cos\dfrac{\alpha-\beta+\gamma}{2} \cos\dfrac{\alpha-\beta-\gamma}{2}= 2z.\cos\dfrac{\pi-2\beta}{2}\cos\dfrac{\alpha-(\pi-\alpha)}{2}## ##\\[5 pt]##
##=2z\sin\beta\cos(\alpha-\pi/2)=\boxed{2xyz}## = R.H.S.
