Prove Basis to Basis Isomorphism
  • Thread starter Thread starter iamalexalright
    Basis Isomorphism
10 replies · 9K views
iamalexalright
Let [tex]t \in L(V,W)[/tex]. Prove that t is an isomorphism iff it carries a basis for V to a basis for W.
L(V,W) is the set of all linear transformations from V to W
So I figured I would assume I have a transformation from a basis for V to a basis for W and prove that it is bijective (and hence isomorphic).
So let [tex]B_{v} = \{v_{i} | i \in I\}[/tex] be a basis for V and
[tex]B_{w} = \{w_{j} | j \in J\}[/tex] be a basis for W
So t is surjective if im(t) = W so...
[tex]im(t) = \{tv_{i} | v_{i} \in B_{v}\} =[/tex]
[tex]\{w_{j} | w_{j} \in B_{w}\}[/tex]
Since B_w spans W can I simply say then that, given above, the next line would be:
= W
so im(t) = W
Now to prove it is injective I need to show that ker(t) = {0}
[tex]tv_{i} = tv_{j}[/tex] implies
[tex]t(v_{i} - v_{j}) = 0[/tex] implies
[tex]v_{i} - v_{j} \in ker(t)[/tex]
If ker(t) = {0} then implies v_i = v_j but this doesn't seem like a formal way to prove this... any help?
= W
so im(t) = W
So, you have assumed that if [tex]v_i[/tex] is a basis element of V then its image under t is [tex]w_i[/tex], which is a basis element of W. Now, observe that, by assumption, no two basis elements of V are mapped to the same basis element in W. Now, write your [tex]v_i,v_j[/tex] as a linear combo of vectors in V and then use the linearity of t to distribute it across the linear combo.
Also, you need to prove that if t is an isomorphism, then it maps a basis of V to a basis of W, that is, the image of the basis of V under T forms a basis of W.
So i did assume it was 1-1.
okay, well for v_i in the Basis of V:
[tex]t(a_{1}v_{1} + ... + a_{n}v_{n} =[/tex]
[tex]a_{1}tv_{1} + ... + a_{n}tv_{n}[/tex]
If it is an isomorphism then the ker(t) should be zero:
[tex]ker(t) = \{v \in B_{v} | tv = 0\}[/tex]
so:
[tex]a_{1}tv_{1} + ... + a_{n}tv_{n} = 0[/tex]
since I assume t maps to a basis in W then the only solution to this is when a1...an = 0 so that implies that the ker(t) = {0}, yes?
Now the image of t is simply tv, and since I assume tv is in a basis of W then the image spans W so I can write im(t) = W. Correct?
I still feel i am wrong
so:
You have done enough to show that t is 1-1 and onto and hence an isomorphism. The only problem is that you need to be a *little* more formal in your proof that it is onto, but you have the idea.
I'd start by writing every element in W as the linear combo of a basis for W. Which basis? Well, given your assumptions (that is, T takes a basis for V to a basis for W) which basis do you think you should use?
Yeah, when I write it up I will take care of being a bit more formal
let [tex]u \in W[/tex]
then
[tex]u = a_{1}w_{1} + ... + a_{n}w_{n}[/tex]
where w is in a basis for W
then since [tex]w_{i} = b_{1}tv_{1} + ... + b_{n}tv_{n}[/tex] (v in basis for V)
we can combine and get:
[tex]u = a_{1}[b_{11}tv_{1} + ... b_{n1}tv_{n}] + ... + a_{n}[b_{1n}tv_{1} + ... + b_{nn}tv_{n}][/tex]
simplifying:
[tex]u = c_{1}tv_{1} + ... + c_{n}tv_{n} =[/tex]
Thanks for the help
One simplifying step:
You are saying that T maps SOME basis of V to SOME basis of W. So, you don't know what the bases are, but you know there exists a basis for V and a basis for W such that T(v_i)=w_i. Now, write your arbitrary element of W as a linear combination of the w_i's. This way you can skip the portion about combining the linear combinations.Now, if you haven't, you need to prove the other way of this bi-conditional statement. That is, assume that it is an isomorphism and show that it maps a basis of V onto a basis of W.
So if it is an isomorphism we know that
im(t) = W so each w in W can be written as a combination a_1*tv_1 + ... + a_n*tv_n
since the kernel(t) = {0} this implies only the zero vector is a solution to:
a_1* tv_1 + ... a_n* tv_n = 0
so then these vectors v_n are linearly independent. I don't know how to show that these span V however.
Eh... not so sure about these half of it..
It hasn't been said explicitly, but if T is an isomorphism from V to W, then what can you say about the dimensions of V and W. That is, which one, if any, is true:
dim(V) < dim(W)
dim(V) >dim(W)
dim(V) <= dim(W)
dim(V) >=dim(W)
dim(V) = dim(W)
(HINT: use nullity plus rank theorem and use the fact that ker(T)={0})
Now, as you pointed out a_1* tv_1 + ... a_n* tv_n = 0 implies that a_1=...=1_n=0. What does this say about these vectors? Now, look to see how many of these vectors you have. Do you have a basis?
The dimensions are the same
if the coeffecients being zero is the only way the linear combination of vectors is zero then the vectors are linearly independent. I have n vectors so assuming the dimension of my space is n then I have a basis.
Perfect! You have shown a)T is 1-1 b)every w in W is a linear combo of the T(v_i)'s, so T is onto.
You're done!
: D
Thanks so much for the help!
