Prove/Disapprove n2 + 3n + 1 is prime for n > 0
  • Thread starter Thread starter blackle
    Prime
The discussion revolves around the expression n² + 3n + 1 and whether it is always prime for integers n > 0. Participants are exploring the properties of this polynomial and its potential to yield prime numbers.
  • Some participants suggest using mathematical induction as a possible approach. Others discuss the implications of factoring the polynomial and what it means for the expression to be composite. There are also references to similar problems involving other polynomial expressions.
The conversation is ongoing, with participants sharing insights and questioning the validity of the original statement. Some have provided examples of specific values of n and their corresponding outputs, while others have noted the importance of counterexamples in disproving universal claims.
Participants are considering the implications of the polynomial's behavior at various integer values and discussing the nature of prime and composite numbers in relation to polynomial expressions. There is an acknowledgment that proving or disproving such statements may require deeper exploration of number theory concepts.
blackle
Prove or disprove that n2 + 3n + 1 is always prime for integers n > 0.
I am at a complete loss. I don't even know where to begin.
Following are the formulas that I feel might be relevant:
1) a and b are relatively prime if their GCD(a, b) = 1
2) If a and b are positive integers, there exists s and r, such that GCD(a, b) = sa + tb
3) If ac ~ bc(modm) and GCD(c, m) = 1, then a ~ b(modm)
~ stands for is congruent
Any help would be appreciated. All I need to is a guiding stone to the solution.
I haven't attempted it, but it seems like induction would be a good one to try
If n2 + 3n + 1 were composite, it could be factored into (n + a)(n + b) for some integer values a and b.
welcome to pf by the way ;)
much easier
I second lanedance's welcome.
This problem makes me think of another one I saw a long time ago, where you're supposed to prove or disprove that n2 + n + 41 is prime for all positive integers n. As it turns out, when n = 40, you get 402 + 40 + 41 = 402 + 2*40 + 1 = (40 + 1)2, which is obviously not prime.
Let f(n) = n^2 + 3n + 1
When n = 1, f(1) = 5, which is a prime.
When n = 2, f(2) = 11, also a prime.
When n = 3, f(3) = 19, also a prime.
When n = 4, f(4) = 29, also a prime.
When n = 5, f(5) = 41, also a prime.
How about when n = 6? f(6) will give you what value? Is the value prime or composite? :)
Correction: If n2 + 3n + 1 were composite, it could be factored into abbn for some n.
Those are *some* of the tools you would need to prove it.
Hint: One way to disprove the conjecture "all positive integers are even" is to say "1 is odd". One counterexample is all that is to disprove a universal statement.
Aren't we saying essentially the same thing? My n + a is your ab and my n + b is your bn (or vice versa).
I don't think so. My interpretation of your post is that you were giving a hint to the OP regarding the ability/inability to factor 2+3n+1 into the form (n+a)(n+b), where a and b are some fixed integers.
If that interpretation is correct we are saying something quite different.
Thank you! That was of great help :)
Yes, your interpretation is correct, but I'm not seeing the difference, unless the difference involves a qualifier.
For n2 + 3n + 1 to be composite how is saying that it must factor into (n + a)(n + b) for some integers a and b different from saying that it factors into anbn?
Maybe a different example would be enlightening, say n2 + 19n + 34. This polynomial is factorable into (n + 2)(n + 17), so for an integer n, n2 + 19n + 34 is composite. Is the difference between these two examples the difference between "for some" and "for all?"
Exactly. That n2+19n+34 factors into (n+2)(n+17) means that n2+19n+34 is a composite number for all positive integers. Always. That n2+3n+1 does not factor merely means that n2+3n+1 is not always a composite number. It does not means that it is always prime.
There is no such thing as a non-constant polynomial that yields a prime for all integers n.
OK, I get it now. The number theory class was several decades ago...
