Prove/disprove these subgroups
  • Thread starter Thread starter RJLiberator
The discussion revolves around proving or disproving whether certain sets are subgroups of the symmetric group \( S_n \) and the dihedral group \( D_n \). The original poster presents three specific cases involving permutations and their properties related to identity, closure, and inverses.
  • Participants explore the definitions of subgroups and question the original poster's reasoning regarding the identity and closure properties of the sets in question. There is a focus on clarifying what constitutes a rotation and reflection within the context of \( D_n \).
There is an ongoing exploration of the subgroup definitions, with some participants providing clarifications and questioning assumptions made by the original poster. Multiple interpretations of the subgroup criteria are being discussed, particularly regarding the mappings of elements in the sets.
Participants note that the identity element and the operations defined in the context of \( S_n \) and \( D_n \) are crucial for understanding the subgroup properties. There is also mention of the need for clarity on the definitions of rotations and reflections, as well as the implications of the variable \( n \) in the sets being discussed.
RJLiberator
Prove or disprove each of the following:
a) {f ∈ S_n | f(1) = 1} is a subgroup of Sn
b) {e}∪{f∈D_n | f is a rotation} is a subgroup of D_n
c) {e} ∪ { f∈D_n | f is a reflection} is a subgroup of D_n
e = identity element
Subgroup if:
i) e exists (identity)
ii) if x, y exist in the set then x*y exists
iii) for all x existing in the set, there is an inverse existing.
a) we can prove that this is indeed a subgroup by following the subgroup definition
1. the identity is 1 and that exists in f(1) = 1.
2. For everything that exists in f(1)=1, 1*1 = 1. That exists still.
3. Since 1 is the only thing that exists in this set, 1*1 = 1 which is also the inverse element.
So yes, this is a subgroup of Sn.
b) 1. The identity clearly is part of this set.
2. since all elements are rotations, then they all exist when you multiply each of them. rot1*rot2 = just some other rotation?
3. Wouldn't the inverse be the opposite rotation?
c) 1. The identity clearly is part of this set.
2. the reflections all exist, if you multiply them, theyll just be reflections that still exist.
3. Wouldn't the inverse be the opposite reflection?Is my thinking correct?
Thank you.
"f(1) = 1" is not a set, you cannot have something that exists in it.
{f ∈ S_n | f(1) = 1} has more than the identity element. For n=3, it has (f(1)=1, f(2)=3, f(3)=2) for example.
What exactly is a rotation? A cyclic permutation? Same question for reflection.
That's what you have to find out.
Sure.
I understand ##S_n## is the symmetric group. What is ##D_n## ?
I see, so now I am unclear on what a) is trying to say. They say f exists in S_n such that f(1) = 1. But this implies that f(2) = 3 somehow? How is that possible?@geoffrey159 I am unsrue what D_n signifies here. It wasn't brought up to us in our notes yet. I may have to do some digging.
It does not. I made an example.
Oh, I see now, the n dictates it.
So, if n = 4
then we can safely say that f(2) = 2, f(3) = 3, f(4) = 4
correct?
So, if n = 4
correct?
That is one of your permutations in the set. It is not the only one.
f(1)=1, f(2)=2, f(3)=4, f(4)=3 is another one in the set, and there are more.
Dihedral groups - okay, then reflections and rotations are clear.
You'll have to prove that.
Okay so let's start with a then. I thought I initially had it, but clearly I was a bit off.
Subgroup if:
i) e exists as e exists in a symmetrical group?
ii) if x,y are elements in this set that is defined by the question, then x*y exists as f(x) = x and f(y) = y so f(xy) = xy.
iii) Identity exists as it must in a symmetric group?
Meh, this is not going well.
Subgroup if:
This is somewhat unclear.
Basically, a subgroup is a subset of a group that is also a group under the same binary operation as the group.
To paraphrase your definition:
A ⊆ Sn is a subgroup if:
i) e ∈ A (identity)
ii) if x, y ∈ A, x*y ∈ A
iii) if x ∈ A, x-1 ∈ A
For a), you have to prove that A = {f ∈ Sn | f(1) = 1} is a subgroup of Sn.
Referring to the definition of a subgroup, you have answer the following questions:
i) is the identity permutation in A?
ii) if f,g ∈ A, meaning f(1)=1, g(1)=1, is f*g (where the * stands for the group operation of Sn) also in A?
iii) if f ∈ A, meaning f(1)=1, is f-1 ∈ A ?
If the answer is Yes to all of them, A is a subgroup.
Here's what I am a bit unclear of. We talk of * being the group operation, but how is the group operation defined in the problem?
Is this something about S_n that I am not knowing/using.
I see the identity permutation as being f(1)=1. done!
I see, ii) being simply done as f*g = f(1)g(1) = 1*1 = 1 done!
I see iii) as f(1)=1=e=so yes it works.
Perhaps my proof is written hastly and unclear, but i hope you can see what I mean. While I am struggling with the correct notation and wording, I think i have the general idea of this part done. I would say that part a is definitely a subgroup.
The key distinction for me is what is the operation here and what is the identity. If the identity is simple "1" then yes it all works out for me.
Let's start with this one.
Sn is by definition the group of all permutations of a finite set of n elements.
Traditionally, one takes as set S={1,2,3,...,n}, and Sn is the set of all permutations of S.
But, the numbers in S are not important. You could, instead of using {1,2,3,4} for the definition of S4, use the sets S'={a,b,c,d}, S"={cat, dog, lion, tiger}, ... Any set consisting of exactly 4 elements.
So, when you have to check something about f*g for f,g ∈ Sn, f*g is the composition of two permutations. First you apply g, then f. The product 1*1, as you wrote, is irrelevant. If we had used the set S", how would you have calculated cat*cat?
The group operation is composition of functions (here permutations). The identity is not the number 1, but the identity permutation, the permutation that maps each element to itself.
If we denote the identity element of S4 by e, then:
e(1)=1
e(2)=2
e(3)=3
e(4)=4
Here I used the usual set {1,2,3,4}.
If I want to be a little silly and use S"={cat, dog, lion, tiger}, then e, the identity element of S4 would be the following permutation:
e(cat)=cat
e(dog)=dog
e(lion)=lion
e(tiger)=tiger
In this case, of course, part a) of the exercise would be: prove that {f ∈ Sn | f(cat)=cat} is a subgroup of Sn.
Let us not be silly, and stick with permutations of {1,2,3,4}. Just remember that these numbers are symbols, and that multiplying them as numbers (1*1,2*3) is irrelevant when discussing S4.
I think the problem is the set definition. A = {f ∈ Sn | f(1) = 1} is the set of all permutations where the number 1 is mapped onto the number 1. The other elements can be mapped in any way. Now you have to show:
(i) the identity permutation is a permutation where 1 is mapped onto 1 (well, that is trivial)
(ii) if you perform two permutations which both map 1 onto 1, then the resulting permutation is also one where 1 is mapped onto 1
(iii) the inverse permutation to any permutation that maps 1 onto 1 is again a permutation that maps 1 onto 1.
Okay, thank you both for the words. Samy_A I think you did much to improve my understanding of this problem.
With mfb's i, ii, and iii, words, let me try this:
Could we say, by the definition of the statement, we have the permutation. Since the statement was f(1)=1, this IS the identity permutation.
Here, I am a touch confused, as we noted earlier and as you said now:
So you are saying that the other elements could be mapped as f(2) = 3. But this is NOT the identity permutation.
How do I deal with this? Is it enough to simply say, by the definition we see f(1)=1 so the identity permutation exists?
Is this as simple as saying (f°f)(1) = 1 = f(1)f(1)@Samy_A
I just don't understand how you could. From the looks of it, we don't have a defined operation. We say that it is a permutation. So cat*cat would be a permutation on cat with a permutation on another cat.
That does not make sense. f(1)=1 is not a permutation. It is an equation, telling you something (but not everything) about f. Don't take that out of context. Your set of permutations is A = {f ∈ Sn | f(1) = 1}. It is not "f(1)=1".
What is f(1)f(1)? There is no multiplication involved at all. The group operation means (f°f)(1) = f(f(1)).
You cannot, that is the point. Yet you try to do so with "1*1". Which has some reasonable definition with real numbers but that is pure coincidence.
Precisely. I suppose that it was I meant.
Ok. So I've been reading on wiki about permutations and so forth. I feel like, what I have is the following:
[ 1 2 3 ... n ]
and this symmetric map maps to
[ 1 x x ... x ]
Where I don't have any further knowledge on what x is other than the fact that this is a symmetric group.
Considering I don't know what x is in the symmetric group, all I feel I know (based on my lofty definition of symmetric groups) is that x is unique and one to one, and all x's possible get mapped to some number.
In theory, let's say we have
[1 2 3 4] maps to (map f)
[1 3 2 4]Could I say then, well the identity is available as f(f(2)) = 2 (this is just an example for understanding not a full fledged proof yet)
[ 1 2 3 ... n ]
[ 1 x x ... x ]
Yes. The identity element e of S4 maps 1→1, 2→2, 3→3, 4→4. So certainly it satisfies e(1)=1, and thus is an element of A.
Now you still have to prove point iii) as mentioned by @mfb , and that will conclude part a) of the exercise.
So, to summarize.
i) e is an element of A as e(1)=1.
ii) We have associativity as f(1)f(1)=1=(f*f)(1) where * is the composition of the two maps.
iii) The inverse is part of A as f(1)*f(1) = 1 = e
Does that wrap up part a correctly?
RJLiberator said:
So, to summarize.
Not really.
i) is correct.
ii) f(1)f(1) doesn't make any sense. You have to prove that for f,g ∈ A, f°g ∈ A.
iii) Again, f(1)*f(1) doesn't make any sense. You have to prove that for f ∈ A, f-1 ∈ A.
Remember that by definition of A, f ∈ A means that f(1)=1.
but there is no g and that is my confusion, perhaps you guys have told me over and over in this thread and its not hitting me.
Let me think.
If we let g(1)=1 and f(1)=1 then we have a g, I guess. So f°g(1) = f(g(1)) = f(1) = 1.
Now that seems more correct, I think.
for iii), for f(1)=1, f^-1 exists as f°g(1)=e. Letting g(1)= 1 as prescribed in the definition statement we see g(1) = f^(-1)
You have to prove that A is a subgroup. That means (among other things) that the group product of two elements of A is also an element of A.
To do that, you have to take two arbitrary elements of A, give them a name (I used f and g), and see if the product is in A. You did this correctly, see below.
RJLiberator said:
Let me think.
Yes, that is all there is to it for ii).
Well, this is somewhat unclear. I assume that g=f-1. You don't have to "let g(1)=1",you have to prove that this the case for g, the inverse of f ∈ A.
Excellent. I am starting to learn this and i'll try to apply it to parts b and c next ( either now or tonight).
Yes g=f^-1 and so (f°g)(1) = e implies that g is the inverse.
f(g(1)) where g(1) = 1 so then we have f(1) = 1 = e.
I think you have things backward here. You know that f ∈ A, meaning f(1)=1.
You have to prove that g(1)=1.
Hint: since g=f-1, g°f=e (where e is the identity element of S4, the permutation that sends each element to itself).
RJLiberator said:
(f°g)(1) = e
That is not true. The left side is a number, the right side is a permutation, they cannot be equal.
(f°g) = e - combining both gives the identity element (which is what you want)
(f°g)(1) = e(1)=1 - here we look where 1 gets mapped to. This equation follows from the one above.
Now you have to prove g(1)=1.
