Prove Isomorphism When Columns of C are Linearly Independent
  • Thread starter Thread starter LosTacos
    Isomorphism Proof
The problem involves proving that a linear operator L represented by a matrix C is an isomorphism if the columns of C are linearly independent. The discussion centers around the implications of linear independence in relation to the properties of the linear operator.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the relationship between linear independence of the columns of C and the properties of the linear operator L, specifically questioning how this leads to L being one-to-one and onto. There are attempts to clarify the definitions of injective and surjective functions, as well as the implications of the trivial solution in the context of the homogeneous equation.
The discussion is ongoing, with participants raising questions about the definitions and implications of linear independence and the properties of the linear operator. Some guidance has been offered regarding the relationship between injective and surjective operators, but no consensus has been reached on the proof itself.
There is a noted ambiguity regarding the mapping of L and whether it is assumed to be from R^n to R^n. Participants are also considering the implications of linear combinations and the uniqueness of solutions in relation to the linear independence of the columns.
LosTacos
Let L:R->R be a linear operator with matrix C. Prove if the columns of C are linearly independent, then L is an isomorphism.
Assume the columns of C are linearly independent. Then, the homogenous equation Cx=0 is the trivial solution. Need to show L is both 1-1 and onto. Assume that L(c1)=L(c2). Need to show that c1=c2. Well, since the matrix is linearly independent and Cx=0 is trivial solution, then each column represents its own solution. Therefore, if L(c1)=L(c2), then it must be that c1=c2. Now need to show L is onto. So for every d, there exists a c such that L(c)=d. Since C is linearly independent, no vector can be expressed as a linear combination of others. So, for each d, there will be a c where L(c)=d. Therefore, L is an isomorphism.
I think this should be L:Rn->Rn?
An equation is not the same as a solution. The equation has the trivial solution only.
How do you mean that?
Hint: Use linearity.
"is onto"?
No vector of your matrix, right.
That does not follow from the previous statement.
Okay so the equation has the trivial solution. So that means that the only solution is the trivial one, which is represented by the columns themselves, therefore 1-1. And since C is linearly independent, no vector in the matrix can be expressed as a linear combination of otheres. Therefore, each output has an input where L maps to that.
The columns have no relation to the trivial solution. The trivial solution is x=0.Consider the linear operator F:R->R2, F(x)=(x,0). It satisfies everything you list in your posts, but it is not surjective: there is no x such that F(x)=(1,1). As long as you do not use that L maps Rn on itself, the argument cannot work.
so how do you go about showing it is surjective
Because the columns of A are linearly independent, each column will have a unique solutions such that there will exist an x such that L(x)=b which implies Ax=B
Injective linear operators from R^n to R^n are always surjective. This follows from a more general result about the dimensions of the image and the kernel.
  • · Replies 30 ·
