MHB Prove R is a Sub-ring of $\mathbb{Q}$ - Prime $p \in \mathbb{Z}$
  • Thread starter Thread starter fabiancillo
fabiancillo
Hello, I don't know to solve this exercise:
Let $p \in \mathbb{Z}$ be a prime number. Consider $R = \{m/n \in \mathbb{Q}: p$ does not divide $n \}$
How can I prove that $R $ is a sub-ring of $\mathbb{Q}$? (only the obvious parts) and find the group of units of $R, R^{\times}$I have no idea.How can I solve ?
Thanks
Hi cristianoceli,
One of the equivalent definitions for a subring is:
"A subset S of R is a subring if and only if it is closed under multiplication and subtraction, and contains the multiplicative identity of R."
How far can we get with those conditions?
Klaas van Aarsen said:
Hi cristianoceli,
Can you explain? Sorry
In the exercise I do not know if this happens
Suppose we have the elements $\frac{m_1}{n_1}$ and $\frac{m_2}{n_2}$. It means that $p$ does not divide $n_1$, and $p$ does not divide $n_2$ either.
Is $\frac{m_1}{n_1}\times\frac{m_2}{n_2}$ always an element of $R$?
If it is, then $R$ is closed under multiplication.
I understand but .
What are the units of $R$?
The units of a ring $R$ are the elements that are invertible with respect to multiplication.
Which elements are invertible?
$1$ ,$-1$ and prime numbers $\neq p$?
Those are indeed units, but there are more.
The multiplicative inverse of $\frac{m}{n}$, if it exists in $R$, is $\frac{n}{m}$.
What do we need for $\frac{n}{m}$ to be an element of $R$?
$p$ does not divide $m$
$R^{\times} = m \in \mathbb{Q} $ such that $p$ does not divide $m$ ?
cristianoceli said:
$R^{\times} = n \in \mathbb{Q} $ such that $p$ does not divide $m$ ?
That should be: the set of units of $R$ is $\{m/n\in\mathbb Q : p\text{ does not divide }m \land p\text{ does not divide }n\}$.
This set happens to be a group with respect to multiplication named $R^\times$.
I understand.
Thank you
  • · Replies 21 ·
