MHB What are the properties of distance?
  • Thread starter Thread starter mathmari
    Properties
The discussion centers on the properties of distance in Euclidean space, specifically the definitions and implications of the distance function \(d(v, w) = |v - w|\) and the distance between sets \(d(V, W) = \min \{d(v, w) \mid v \in V, w \in W\}\). Participants confirm that \(d(u, w) = 0 \iff u = w\) is a direct consequence of the properties of the Euclidean norm. However, concerns are raised regarding the use of "min" in the definition of distance between sets, as it may not always be attained, suggesting the use of "least upper bound" instead. The discussion also touches on the distinction between various metrics, including the Minkowski metric, which does not conform to traditional metric definitions.
  • Understanding of Euclidean space and norms
  • Familiarity with distance functions and their properties
  • Knowledge of set theory and intersections
  • Basic concepts of different metrics, including the Minkowski metric
  • Research the properties of the Euclidean norm and its implications in vector spaces
  • Study the differences between "min" and "least upper bound" in mathematical definitions
  • Explore various types of metrics, including pseudometrics and quasimetrics
  • Investigate the applications and limitations of the Minkowski metric in physics and mathematics
Mathematicians, physicists, and students studying geometry or metric spaces, particularly those interested in the properties of distance functions and their applications in various fields.
mathmari
MHB
Hey!
Let $v, w\in \mathbb{R} ^n$ and let $V, W\subseteq \mathbb{R} ^n$.
I want to show the following properties :
  • $d(u.,w)=0\iff u=v$
  • $d(V, W) =0\iff V\cap W\neq \emptyset$
I have done the following:
  • $d(u, w) =0\iff |u-w|=0\iff u-w=0\iff u=w$
    Or do we have to do more steps?
  • $d(V, W) =0\iff \min \{d(v, w) \} =0$ this means that there exists $v$ and $w$ such that $d(v, w) =0$ and from the previous one it follows that $v=w$ which means that the intersection is non empty.
    Is that correct?
(Wondering)
Hey mathmari!
What is your function $d$ exactly? (Wondering)
The following definitions are given:
  • $v$ is orthogonal to $w$, if $v\cdot w=0_{\mathbb{R}}$.
  • $|v|:=\sqrt{v\cdot v}$ is the lengthh of the vector $v$.
  • $d(v,w):=|v-w|$ is the distance between the vectors $v$ and $w$.
    $d(V,W):=\min \{d(v,w)\mid v\in V, w\in W\}$ is the distance between $V$ and $W$.
That definition of $d(V,W)$ is very suspicious because the minimum value $\min \{d(v,w)\mid v\in V, w\in W\}$ is not usually attained. For example, if you define $V, W\subset \Bbb{R}$ to be the open intervals $V=(0,1)$ and $W=(1,2)$ then $\inf \{d(v,w)\mid v\in V, w\in W\} = 0$. But $\min \{d(v,w)\mid v\in V, w\in W\}$ does not exist. You can find $v\in V$ and $w\in W$ with $d(v,w)$ arbitrarily close to $0$. But that distance can never be equal to $0$.
With that definition I believe that your proofs are all correct. (Happy)
Suspicious or not, it merely means that the distance of such open intervals is not defined, isn't it?
It would probably be 'nicer' if they used $\inf$ instead of $\min$, but for the problem at hand it does not really matter does it?
Those $V$ and $W$ are probably intended to be linear or affine sub spaces or some such, in which case the distinction would not be relevant. (Thinking)
Can we just say that $|u-w|=0\iff u-w=0$ ? Or do we have to use some more steps in between? (Wondering)
Well, $|\cdot|$ is the Euclidean norm here.
Part of the definition of a norm, is that $|x|=0 \iff x=0$.
So as such we can simply use that. (Nod)
We might mention that it is because $|\cdot|$ is a norm.
To be fair, your $d$ is the Euclidean metric.
Part of the definition of a metric, is that $d(x,y)=0 \iff x=y$ (point separating).
So there was no actual need to prove it. We could have referred to the definition of a metric instead. (Nerd)
@mathmari
Just a note to explain why we need to be careful. The metric (distance function, norm, whatever) you are using is Eudlidean and has all the familiar properties, such as [math]x = 0 \implies ||x|| = 0[/math]. That's because the metric that Klaas van Aarsen mentioned (and is also the one you are using) is positive definite, which means the norm is either 0 or real.
But there are other useful metrics. For example, in SR, we have an indefinite metric, which means that [math]x \cdot x[/math] can be negative, zero, or positive. (Setting c = 1 for convenience the Minkowski metric says that the vector <0, 0, 1, 0> has a norm of -1 and that the vector <1, 0, 1, 0> has a norm of 0.)
There are all sorts of fun metrics out there. (Sun)
-Dan
For the distance between two sets, it would be better to use "least upper bound" rather than "min". In R1 the distance between U= (0, 1) and V= (2, 3) is "lub(|x- y|, x in U, y in V)= 1" while "min(|x- y|, x in U. y in V)" does not exist.
topsquark said:
@mathmari
-Dan
This has been a source of confusion to me. ;)
The so called Minkowski metric does not satisfy the generally used definition of a metric.
Interestingly, the wiki article of a metric does not even mention the Minkowski metric. It does mention various other flavors, such as pseudometrics, quasimetrics, and semimetrics, but the Minkowski metric is none of those!
Moreover, the wiki article for the Minkowski metric does not make any mention that it is not a metric according to the usual definition of a metric.
Confusing indeed!
Either way, as I interpret it, the Minkowski metric is formally not a metric. Instead it is a metric tensor. (Nerd)
(Swearing) Jim, I'm a Physicist, not a Mathematician!
Good catch!
-Dan
  • · Replies 24 ·
