Prove that 1 + NOT (1 + NOT x) = x
  • Level: Undergrad
  • Thread starter lemonfrostt
7 replies · 2K views · last reply
lemonfrostt
In binary, the two's complement representation of a negative number is found by NOT b + 1, with the leading bit being a sign bit. In general, prove that applying the operation NOT b + 1 twice to some n-bit binary number yields the original number b.
I found this conceptually straightforward but hard to satisfactorily prove. Try it yourself.
The set of n-bit binary numbers under (+) form a cyclic group (g = 1) of order 2n.
b + NOT b = 1-1 (Ones' complement).
Therefore 1 + NOT b = b-1. (b-1)-1 = b.
(b-1 denotes additive inverse.)
To be explicit about the order of operations, two's complement is NEG(b) = (NOT b)+1.
NOT b maps [00...00 ... 11...11[ to [11...11 ... 00...00]
(NOT b)+1 maps [00...00 ... 11...11] to [11...11 ... 00...00] and then to [00...00, 11...11, 00...01 ]
we can restate that as:
NEG(b) maps [00...00, 00...01 ... 11...11] to [00...00, 11...11, 00...01 ]
So it keeps 00...00 and reverses the order of all the others.
Doing hits twice will keep 00...00, and reverse the order of all the others twice. Yielding no change.
Is this question for schoolwork? If so, I can move the thread to the schoolwork forums.
The schoolwork question was much weaker. I made it somewhat more difficult to entertain myself.
y=1+NOT(x) ≡ −x (mod ## 2^n##)
1+NOT(y) ≡ −y ≡ x (mod ##2^n##).
Or even better:
T(x)=1+NOT(x) ≡ −x (mod ## 2^n##)
T(T(x)) ≡ −(−x) ≡ x (mod ## 2^n##)
The easiest way to see this is to treat n bit numbers as arithmetic modulo 2^n.
For any n bit number b, NOT b changes every 0 to 1 and every 1 to 0. Numerically, that means NOT b = 2^n - 1 - b.
So 1 + NOT b = 2^n - b, which is equivalent to -b modulo 2^n. In other words, NOT b + 1 gives you the additive inverse of b.
Now apply the same operation again. Since the additive inverse of -b is b, we get 1 + NOT(1 + NOT b) = b modulo 2^n.
So taking the two's complement twice always gives you the original n bit number.
I am not a specialist in this field but it looks like ##1+(1-(1+(1-x)))##
and I think that such operations must be considered in ##\mathbb{Z}_2##
We can define the function ## f(x)=1+\text{NOT}x ## and prove that ## f^{-1}(x)=f(x) ##.
## \begin{align}
f(x)=1+\text{NOT}x&\implies f(x)-1=\text{NOT}x\nonumber\\
&\implies \text{NOT}(f(x)-1)=x\nonumber\\
&\implies f^{-1}(x)=\text{NOT}(x-1)\nonumber\\
\end{align} ##
For
$$ x=(\sum_{i=0}^{n}x_i10^i)_2 $$
where
## \begin{align}
\text{NOT}x&=(\sum_{i=0}^{n}(1-x_i)10^i)_2\nonumber\\
&=(\sum_{i=0}^{n}1\cdot10^i-\sum_{i=0}^{n}x_i10^i)_2\nonumber\\
\end{align}\\ ##
we have
## \begin{align}
f(x)&=1+\text{NOT}x\nonumber\\
&=(1+(\sum_{i=0}^{n}1\cdot10^i-\sum_{i=0}^{n}x_i10^i))_2\nonumber\\
&=(\sum_{i=0}^{n}1\cdot10^i-(\sum_{i=0}^{n}x_i10^i-1))_2\nonumber\\
&=\text{NOT}(x-1)\nonumber\\
&=f^{-1}(x)\nonumber\\
\end{align}\\ ##
