Prove that an integer with digits '1' is not a perfect square.
  • Context: Graduate
  • Thread starter Thread starter futb0l
    Integer Square
The discussion revolves around the challenge of proving that any positive integer composed entirely of the digit '1' (except for the number 1 itself) cannot be a perfect square. Participants explore various mathematical approaches, proofs, and counterarguments related to this assertion.
  • One participant suggests that any integer with all digits as '1' is not a perfect square, prompting the discussion.
  • Another participant introduces the concept of base representation, questioning whether the proof applies universally across different bases.
  • Several participants propose mathematical formulations and sums to represent numbers made up of '1's, with varying degrees of correctness.
  • A participant presents a proof involving modular arithmetic, arguing that the left-hand side of an equation is even while the right-hand side is odd, suggesting a contradiction.
  • Another participant offers a different proof based on the properties of odd perfect squares and their remainders when divided by 8, noting that numbers composed entirely of '1's yield a specific remainder.
  • A participant critiques another's proof, pointing out flaws and misunderstandings in their reasoning about odd numbers and perfect squares.
  • There is a discussion about the nature of infinite sequences and their relevance to the topic, with some participants expressing confusion about unrelated questions posed in the thread.
Participants express a range of views, with some supporting the assertion that integers with all digits as '1' cannot be perfect squares, while others challenge specific proofs and reasoning. No consensus is reached on the validity of the various proofs presented.
Some arguments rely on specific properties of numbers and modular arithmetic, which may not be universally accepted without further proof. Additionally, there are unresolved mathematical steps and assumptions in the proofs discussed.
This discussion may be of interest to those studying number theory, modular arithmetic, or mathematical proofs, particularly in the context of perfect squares and properties of integers.
futb0l
I am having trouble with this one...
Prove that any positive integer whose ALL digits are 1s (except 1) is not a perfect square.
What base? 11 in base 8 is a perfect square.
no, I mean not like 11^8.. I mean prove that 11, 111, 111, 1111... is a perfect square...
I didn't mean 11^8 either, I meant 11 written in base 8. For example, 34 written in base 8 is equal to 3 * 8^1 + 4 * 8^0 = 28 in base 10.
I think it should be:
<br /> N = \sum_{n=1}^\infty (1*10^{n-1})<br />
btw, it should be base 10 then.
I don't think you quite mean that infinite (divergent) sum either, but we get the idea.
ok then cool, i am only 15 - my maths skill is pretty crap.
i think it should be:
<br /> N = \sum_{n=1}^k (1*10^{n-1})<br />
where k can be any positive integer.
suppose x^2 = 1+10+100+...
then mod 10, x=+/-1, that is x = 10r+1 or 10r-1 for some r.
consider (10r+1)^2 = 100r^2+20r+1
this is equal to 1+10+100+...
assume r is not zero, 100r^2+20r=10+100+...
divide by 10,
10r^2+2r=1+10+..
but the rhs is even and the lhs is odd, so it must be that r=0. similarly we reason for x=10r-1 and decide r=0 too.
how come the RHS is even and LHS is odd??
i don't quite understand this stuff, can you recommend me a book or an article that is simple to learn?
my apologies, i meant to say the lhs is even (it is divisible by two) and the rhs is odd since it is 1 plus a multiple of 10
Explanation of matt's proof :
x^2 = 1+10+100+...=1+ 10(1+10+...)=1+10k, say, where k=1+10+..., the number within ().
x^2 = 1+10k means that the units digit of x^2 is 1 (example, 81, 121, etc.)
Now for the units' digit of x^2 to be 1, the units digit of x must be 1 or 9. (example : 11^2 =121, 19^361, but 23^2 must end with 9 and 45^2 ends with 5 etc.)
If the units' digit of x is 1, this means that x can be written as 1 + 10a + 100b +... = 1 + 10r (example : 151 = 1 + 50 + 100 = 1 + 10*15 )
If the units' digit of x is 9, this means that x can be written as 9 + 10a + 100b + ... (10-1) + 10a + 100b +... = 10 + 10a + 100b + ... -1 = 10r -1
(example 69 = 70 - 1 = 7*10 - 1)
Having shown that x must be of the form 10r + 1 or 10r - 1, the rest is just algebra...and is easy to follow in matt's proof.
In the last line, you have 10r^2 + 2r = 1 + 10 + ...
LHS = 2*5r^2 + 2r = 2*(5r^2 + r) = 2n, an even number
RHS = 1+10+100+... = 1 + 2(5 + 50 + ...) = 2n + 1, an odd number
So, if the LHS is an even number and RHS is odd, it should not be a perfect square?? if not please explain the very basics.
i seem to have another proof, every odd perfect square when divided by 8 has a remainder of 1... and noting that if an odd integer is squared the answer is always odd.
and with the exception of 1,11, every positive integer whose all digits are 1 have a remainder of 7. But 11 is clearly not a perfect square.
I think this should be enough proof..
but please explain Matt Grime's proof, because I'd like to learn.
matt's proof is known as reductio ad absurdum or proof by contradiction. You make an assumption (in this case, you assume that some perfect square can be a number of the form 11...1) and then arrive at a logical contradiction (such as the statement "even number = odd number"). This implies that the assumption that was made was incorrect (so it should not be possible to find any perfect square of the form 11...1), and that's what you wanted to prove.
This is a perfectly good proof, as long as you show how these statements are true. They are true, no doubt...but I would imagine that you would have to show, for instance that odd perfect squares leave residues of 1 when divided by 8. You might also have to prove that 11...1 always leaves a remainder of 7 when divided by 8.
The first is proved as follows :
N=(2k+1), say, some odd integer.
N^2 = 4k^2 + 4k + 1 = 4k(k+1) + 1
Since k and k+1 are consecutive numbers, one of them must be even. So their product must also be an even number. So k(k+1) = 2m, say.
Then N^2 = 4*2m + 1 = 8m + 1.
This last equation tells you that N^2, when divided by 8, gives a remainder of 1.
To prove that 11...1 leaves a remainder of 7, do the following :
i. Write this as the sum of powers of 10, as in post#8
ii. What happens when you divide 1000 by 8 ? And higher powers of 10 ?
iii. This argument leaves you with having to find the remainder for only 111, which is 7 (all other numbers of the form 11...1 have the same remainder as 111).
Now you are really done.
For a 15 year old, your math skills are far removed from "pretty crap."
just the answer that i wanted, thanks a lot Goku|43201 and also matt grime.
The answer to this question
Tn=a+(n-1)d
a=11
...n
d=10
......1
T1=11+(1-1)10 = 11
......2
T2=11+(2-1)10 = 111
......3
T3=11+(3-1)10 = 111
Tn=a+(n-1)d
.......2
To be a perfect square = x = Tn
11 is not a squared number and it is an odd number so (a=11) is not a squared number and it is an odd number.
...............n
So (n-1)d is always an even number because ( d=10 ) is always an even number So (n-1)d is always an even number
So if you add an even number with an odd number the answer is always an
odd number. So Tn is always an odd number. So an odd number can never be a square.
Even though this could be obvious once you read the question this is the way to prove that all the positive integers where digits are 1s (except 1) is not a perfect square.
Supundika,
This is NOT the way to prove this. You proof is fatally flawed.
An odd number can never be a square ?? How about 1 or 121 ?
Also, the very basis of your argument is incorrect. First of all, d is really d^n, but even that doesn't fix it.
T(3) = 11 + 2*1000 = 2011, definitely not 1111 .
So you start off wrong, and even if you didn't, all you would be proving is that 111..1 is an odd number : a rather convoluted way to prove something that simple.
...this is the way to prove that all the positive integers where digits are 1s (except 1) is not a perfect square.
I suggest you be more sure of your math before you go about proclaiming the superiority of your faulty proof over others previously provided.
Gokul43201,
Your skill in mathematics is really impressive;it is a fact whether i envy it or not. it is good to point out other's mistakes but i am sorry i have to say that your criticism about Supundika is not nice at all.
Yes Leong, you're right - I shouldn't have said that. I take back what I said, and apologize.
Nevertheless Supundika, I strongly suggest you be sure of your math before you post, lest you mislead people that come here to get doubts cleared.
does an infinite string have an end?
What does tihis have to do with whether 111... 111 is a perfect square?
If you have a completely different question, start a new thread- don't "hijack" one that already exists for a different question.
The answer to your question is "No, by the definitonof "infinite string".
Is this proven by noting the square of any any single digit no. would yield a 1 in the units' place only if it were 9 or 1? Is there a proof for this, or is this self-evident?
there is a proof and it is self evident too, if you're used to modulo arithmetic, since you only need to consider the numbers 1 to 9, square them and look at the units column. why? well, it is obvious if you've done some ring theory but if not we can explain it as:
let x = 10q+r, where 0<=r<9
x^2 = 100q^2+20rq + r^2
and neither of the terms involving q can have any contribution to the units column.
Actually I asked the question because I was wondering how rigorous maths should be, and to what extent intuitive proof would suffice. What is ring theory?
Intuition may help you decide what is true and why, but does not itself constitute a proof.
Rings are abstract generalizations of the integers; they are sets that have two operations addition and multiplication that obey certain rules. A very common example, almost the first one students meet that isnt' the integers, is remainder arithmetic, or modular arithmetic.
matt's argument is similar to yours futbol. he notes that every number of form 111111...1,
when divided by 10, has remainder of 1. hence if it is a square of some number A then since the remander of the square is the square of the remainder, the number A must have remainder 1 or -1 when divided by 10. so he checks both cases, and neither works.
i wrote this before noting there was a second page of comments.
Here's a little more regarding Matt Grime's proof:
"let x = 10q+r, where 0<=r<9
x^2 = 100q^2+20rq + r^2"
and as he noted, r must be 1 or 9
If it is 1 there is no carry, so the ten's value will be 2rq, which is even and not 1.
If it is 9 then r^2 = 81, so carry the 8. But then 8 + 2rq needs to end in 1, but is even.
Follow up
Hi, I'm new to the forum and came across this thread, I'm aware that the topic is a few years old. I have an interesting question which seems to be an offspring of the topic at hand.
If p is a prime number greater than 3, evaluate p^2(mod 12)
I know this is closely tied to the arthmetic modular or the so-called clock arthemtic. How do you go about proving this. When you work out the numbers every prime square mod 12 beomes 1. Therefore, this is an equivlanence relationship. What I found most interesting is when I tried the primes less than 3 (2, 3) they were not equal to 1. Any thoughts and comments would greatly be appreciated.
Mike
  • · Replies 23 ·
  • · Replies 33 ·
  • · Replies 25 ·
  • · Replies 18 ·
