Prove the identity matrix is unique
- Thread starter askmathquestions
- Start date
69 replies · 14K views
Mentor
- 38,154
- 10,762
WWGD said:Ok, but just how are the two different?
You wrote ##A(I_1 - A_2)## but I thought you meant ##A(I_1 - I_2)##.WWGD said:I'm not aware of any particular meaning of ##[I1−I2]##..
If ##A(I_1 - I_2) = 0##, then using determinants you can deduce that ##I_1 = I_2##, which was the whole point in being able to say that the identity matrix must be unique.
Homework Helper
- 7,917
- 13,233
True, if we assume ##A## is invertible. Otherwise, its right kernel isn't trivial, i.e. , it's not just ##\{0\}##, so in that case of ##A## being singular, it doesn't follow that ##I_1=I_2##. But if ##A## is nonsingular, then you're right.Mark44 said:You wrote ##A(I_1 - A_2)## but I thought you meant ##A(I_1 - I_2)##.
Homework Helper
- 9,629
- 4,850
From the beginning of this thread, it must be stated that the identities, ##I_1## and ##I_2##, work as identities for every possible ##A##. Otherwise, the conclusion that ##I_1=I_2## may be false.WWGD said:True, if we assume ##A## is invertible. Otherwise, its right kernel isn't trivial, i.e. , it's not just ##\{0\}##, so in that case of ##A## being singular, it doesn't follow that ##I_1=I_2##. But if ##A## is nonsingular, then you're right.
Homework Helper
- 7,917
- 13,233
Ok, I guess I lost track of the " Initial Conditions". Using the Determinant alone ( assuming ##A## is square:FactChecker said:From the beginning of this thread, it must be stated that the identities, ##I_1## and ##I_2##, work as identities for every possible ##A##. Otherwise, the conclusion that ##I_1=I_2## may be false.
## Det(A(I_1-I_2))= DetADet( I_1-I_2))=0## implies either of the determinants is ##0##.
Though ## Det( I_1-I_2)=0## doesnt imply ##I_1=I_2##.
But I admit I may have somewhat lost track of were the discussion veered.
Mentor
- 50,998
- 27,036
For the OP question it should not matter; uniqueness of the identity should be provable for any group (or at least any group that doesn't have some other weirdness like zero divisors). @FactChecker seems to me to have come up with the simplest derivation.PeroK said:I completely missed that we were talking about rectangular matrices!
- 29,912
- 21,801
The set of ##m \times n## matrices (where ##m \ne n##) do not form a multiplicative group. The usual matrix multiplication is not even well defined.PeterDonis said:For the OP question it should not matter; uniqueness of the identity should be provable for any group (or at least any group that doesn't have some other weirdness like zero divisors). @FactChecker seems to me to have come up with the simplest derivation.
Mentor
- 50,998
- 27,036
And in such cases there is no "identity" at all. So the OP question isn't even applicable.PeroK said:The set of ##m \times n## matrices (where ##m \ne n##) do not form a multiplicative group. The usual matrix multiplication is not even well defined.
- 29,912
- 21,801
An ##n \times n## matrix is a linear transformation on the set of ##n \times m## matrices (under left multiplication). The question related to the identity transformation in this context.PeterDonis said:And in such cases there is no "identity" at all. So the OP question isn't even applicable.
- aalma
- · Replies 7 ·
- Linear and Abstract Algebra
- Replies
- 7
- mathmari
- · Replies 13 ·
- Replies
- 13
- rocomath
- · Replies 48 ·
- Precalculus Mathematics Homework Help
- Replies
- 48
- lfdahl
- · Replies 1 ·
- General Math
- Replies
- 1
- Dosmascerveza
- · Replies 4 ·
- Replies
- 4
- Marrrrrrr
- · Replies 3 ·
- Quantum Physics
- Replies
- 3
- klmathlover
- · Replies 7 ·
- Replies
- 7
- ognik
- · Replies 5 ·
- Replies
- 5
- A.Magnus
- · Replies 4 ·
- Replies
- 4
- k8thegr8
- · Replies 3 ·
- Calculus and Beyond Homework Help
- Replies
- 3
