Prove ∫x²e^(-x²) = (1/2)∫e^(-x²) from 0 to ∞
  • Thread starter stonecoldgen
    Integration
8 replies · 3K views · last reply
stonecoldgen
Show that:
∫(x^2)e^(-x^2)=(1/2)∫(e^(-x^2)
(both integrals are from 0 to ∞)
I don't even know if it's possible to integrate these functions, so it makes me think that what's interesting about the problem is that it only works with this integration limits.
I know improper integration, but don't know if prooving this "numerically" is the right path.
Thanks, I would appreciate any advice
stonecoldgen said:
Show that:
Hint:
[tex]\int_0^{\infty} x^2e^{-x^2}dx = \int_0^{\infty} x.(xe^{-x^2})dx[/tex]
Integrate that by parts (use [itex]u = x, dv = xe^{-x^2}dx[/itex]), then use L'Hopital's Rule to calculate the limit of one of the expressions.
Curious3141 said:
Hint:
is this correct?
I integrated by pats (differentiating x and integrating x^2e^{-x^2} )
until I got to the point where (e^{-x^2})/2 (evaluated from o to infinity)=0
Using L'Hopital's Rule, I effectively got 0=0
Is this the way?
stonecoldgen said:
is this correct?
Is this the way?
No, I think you messed up the integration by parts. You should end up with:
[tex]\int_0^{\infty} x^2e^{-x^2}dx = xe^{-x^2}|_0^{\infty} +\frac{1}{2}\int_0^{\infty}e^{-x^2}dx[/tex]
and the first expression on the RHS vanishes when you take the limit by L' Hopital's.
It's the same thing (maybe my english isn't that good, I don't know) but Thanks!
How is it the same thing? You said you got "0 = 0" which means nothing. You also said you got [itex]\frac{1}{2}\int_0^{\infty}e^{-x^2}dx = 0[/itex] which is clearly wrong.
Anyway, if you're confident you have the right solution, then it's fine.
What about this one? Show:
∫e-x2=∫√(-lny)
(from 0 to ∞) (from 0 to 1)
I tried this one by solving for y in the right side of the equation, getting y=-ex2
However, when checking the solution graphically, it's not right.
So what the hell am I supposed to do? I also wonder if the integration limits changed when expressed in y or x.
Thanks
You should do a substitution to change the limits and get the log into play, then integrate by parts. Your previous result might help here.
∫e-x2=∫√(-lny)
Thanks
Use this (your previous result):
[tex]\int_0^{\infty} x^2e^{-x^2}dx = \frac{1}{2}\int_0^{\infty}e^{-x^2}dx[/tex]
and make the substitution [itex]e^{-x^2} = y[/itex] on the LHS. The result follows very quickly.
