Integral of 1/(3 + cos x) from 0 to 2π
14 replies · 2K views
madafo3435
No Effort - Member warned that some effort must be shown
I have problems evaluating this integral because every substitution I use turns out to have a discontinuous derivative, or the composition is not well defined.
I write the integral below
I can't advance much in the integral because of what I mention below
## \int_0 ^ {2 \pi} \frac {dx} {3 + cos (x)} ##
las únicas formas que probé fueron, multiplicar por ## \frac{3-cos (x)}{3-cos (x)} ## pero no me gusta esto porque obtengo una expresión muy complicada. También recurrí a la sustitución ## t = tan (\frac {x} {2}) ## que me gusta bastante, pero encuentro que esta función es discontinua en ## \frac {\pi } {2} ## así que no he podido escribir mucho. También probé la sustitución ## cos (x) = \frac {1-t ^ 2} {1 + t ^ 2} ##, pero obtengo el mismo problema con ## \frac{\pi }{2} ##
Use Weierstrass, ##t = \tan{\frac{x}{2}}##. It is quite a useful substitution for fractions with stubborn trig functions.
BvU said:
I'd like to see which ones you tried. PF guidelines require you post your attempt(s)
sorry, it was my mistake not to indicate my attempts. However, the only ways I tried were, multiply by ##\frac {3-cos(x)}{3-cos(x)}## but I don't like this because I get a very complicated expression. I also resorted to the substitution recommended by etotheipi, using the substitution ##t=tan(\frac {x}{2})## which I quite like, but I find that this function is discontinuous in ## \frac {\pi}{2}## so I haven't been able to write much. Also i tried the substitution ##cos(x)=\frac {1-t^2}{1+t^2} ##, but i get the same problem whit ##\frac {\pi}{2} ##
i tried that substitution, but i have problem whit ##\frac {\pi}{2} ## because this function it not continuous at this point.
You want to use it anyway :smile: maybe it doesn't crash...
What is ##dx## in terms of ##t## and ##dt## ?
i find this: ##dx=2cos^2(\frac{x}{2})dt ##. But, I understand that any substitution must be to belong to ##C^1## or is it not necessary?
please observe this attempted solution. By applying the weistrass substitution carelessly, I obtain that the value of the proposed integral gives 0, which is contradictory, since this integral exists and must be positive.
As a first step, I looked at the graph of ##\cos x## and reduced the integral to:
$$\int_0^{2\pi} \frac {dx} {3 + cos x} = 2\int_0^{\pi/2} \frac 1 {3 + \cos x} + 2\int_0^{\pi/2} \frac 1 {3 - \cos x} dx = 12\int_0^{\pi/2} \frac {dx} {9 - \cos^2 x}$$
That gets rid of all the problems with discontinuities.
Now, think ##\sec^2x## and ##\tan^2 x## perhaps.
I haven't lookd carefully at this, but doesn't
$$\int_\pi ^ {2\pi} \frac{dx}{3 + \cos x} = \frac{1}{\sqrt{2}} \tan^{-1} u|_{-\infty}^0 = \frac{1}{\sqrt{2}} \left[0 - \left( -\frac{\pi}{2} \right)\right]$$
you're right, the integration limits confused me. If so, I am satisfied with a solution. thank you
interesting your idea, I like it a lot, I will try to solve it by this method. thanks for your idea
Thank you all for your support, I am satisfied!
One way to avoid this is to note (by, e.g., looking at the graph) that the integrand is even about ##\pi##. It is easily shown algebraically that the integrand evaluated at ##\pi - x## is the same as the integrand evaluated at ##\pi + x##. Consequently, ##\int_0^{2\pi} = 2 \int_0^{\pi}##.
I will keep it in mind, thank you very much for your consideration
