Proving a function is greater than zero
  • Thread starter Thread starter Buri
    Function Zero
The discussion centers on proving that the function f(x,y) = x^p/p + y^q/q - xy is non-negative for x ≥ 0 and y ≥ 0, given the condition 1/q + 1/p = 1. The user attempts to show that the minimum occurs on the line x = y^(q-1), where the function equals zero. They derive a single-variable function h(y) and find its derivative, leading to the conclusion that the minimum occurs at the (q-1)th root of x. The user expresses uncertainty about the positivity of h at this point but believes the approach is valid. The conversation highlights the complexity of proving the inequality and the potential for miscalculations in the analysis.
Buri
I'd like to show that:
f(x,y) = x^p/p + y^q/q - xy ≥ 0 where 1/q + 1/p = 1 and x ≥ 0 and y ≥ 0.
The attempt at a solution
What I'm actually trying to do is show that the minimum is on the line x = y^(q-1) at which the function takes on 0. But proving its actually always ≥ 0 is something that's causing me problems. Is there some inequality that could maybe lead me to a solution? I've tried considering lines in the plane like y = kx, but that doesn't lead me to anywhere. Any help?
We first take x fixed and we consider the function
h(y)=\frac{x^p}{p}+\frac{y^q}{q}-xy
The derivative of this function
h^\prime(y)=y^{q-1}-x
So the minimum of h is in in (q-1)th root of x. So all we need to prove is that
h(\sqrt[q-1]{x})=\frac{x^p}{p}+\frac{x^{\frac{q}{q-1}}}{q}-x^{\frac{q}{q-1}}=\frac{x^p}{p}-\frac{q-1}{q}x^{\frac{q}{q-1}}}
is positive. But since 1/p+1/q=1, we get that the above is equal to 0, and thus always positive.
It could be that I miscalculated somewhere, but I do think that this would be the technique to proving the inequality...
I've worked through it all and it doesn't seem like you did any miscalculations. Is it perfectly sound though? I don't know, but considering the single variable function is something I'm a bit iffy about (I'd think twice about it), but maybe it's just something clever to do.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
