How Do You Prove Vector Spaces Are Isomorphic?
  • Thread starter Thread starter Jennifer1990
    Map
To prove that the vector spaces P3 and R4 are isomorphic, define the map φ: P3 → R4 by φ(a x^3 + b x^2 + c x + d) = [a, b, c, d]^T. This map is bijective because every vector in R4 corresponds to a unique polynomial in P3, ensuring both injectivity and surjectivity. For P5 and M(2,3), a similar approach can be used by defining an appropriate isomorphism that maps polynomials to vectors in R6 and matrices to vectors in R6, demonstrating their structural equivalence. The key to establishing isomorphism lies in verifying that the defined maps preserve vector addition and scalar multiplication. Understanding these concepts is essential for proving the isomorphisms correctly.
Jennifer1990
For each of the following pairs of vectors, define an explicit isomorphism to establish that the spaces are isomorphic. Prove that your map is an isomorphism.
a)P3 and R4
b)P5 and M(2,3)
None
a)I know that P3 and R4 are isomorphic because if the entries in a given polynomial in P3 are written out in a single row (or column), the result is a vector in R4 because we have 4 coefficients in a polynomial of highest degree 3
b)I also know that P5 and M(2,3) are isomorphic because if the entries in a given 2 by 3 matrix are written out in a single row (or column), the result is a vector in R6 , and, likewise, if the entries in a given polynomial in P5 are written out in a single row (or column), the result is a vector in R6 because we have 6 coefficients in a polynomial of highest degree 5
However, I'm not sure exactly sure how the question wants me to write my answers. Could you help me refine my answer so that I am answering what the question wants me to?
How about (for a):
\phi(a x^3 + b x^2 + c x + d \in P_3) = [a, b, c, d] \in \mathbb{R}^4
You still need to show that it's an isomorphism though.
For b you can write down an isomorphism between P5 and R6 and M(2, 3) and R6 and then use that inverses of isomorphisms and compositions of two isomorphisms are again isomorphisms (if you haven't seen that yet, it's easy to prove).
\phi, what exactly is this notation? and how do I show that a) is an isomorphism?
Could you elaborate some more on b). I'm not quite sure i understand what you mean
Do you know what the definition of an isomorphism (between, say, A and B) is?
If A and B are isomorphic,then they are structurally identical. I just know this definition from class. What I get from this is that A and B have the same number elements and they are a one to one mapping :S
OK sounds like you seriously need a good textbook or something :)
So I assume we are talking about an isomorphism of vector spaces (over R). In fact the notion of isomorphism makes sense in a lot of places in mathematics, and could also apply to groups or rings in this context, but I will assume the simplest case.
Definition: Let f: A -> B be a map between vector spaces A and B. f is called an isomorphism if f is a bijective map such that f(x + y) = f(x) + f(y) and f(ax) = a f(x) for all a in R and x, y in A.
Basically, that just says that not only they have the same number of elements, but that they also have the same structure (it doesn't matter if you add two vectors in A and then map them to B, or you first map them to B and add their images).
Definition: Two vector spaces A and B are called isomorphic if there exists an isomorphism between them.
Can you find that somewhere in your class notes or textbook?
So I claim that if you define a map
\phi: P_3 \to \mathbb{R}^4
by
\phi(a x^3 + b x^2 + c x + d) = [a, b, c, d]^T
that is an isomorphism. For this you need to check that
a) phi is bijective (i.e. injective and surjective)
b) preserves structure (i.e. when p, q are polynomials of degree < 4, then phi(p + q) = phi(p) + phi(q))
a) is easy: for every vectors [a, b, c, d] in R4 you can find a polynomial such that the image under phi is [a, b, c, d] (surjective) and if you have two polynomials which both map to [a, b, c, d] then clearly they must be the same polynomial. I'll leave b) for you to try and get used to the definitions.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
