Proving a property in normed vector spaces
  • Topic:
  • Thread starter Thread starter SamJohannes
    Norm Proof Space
6 replies · 2K views
SamJohannes
Hi guys, I've attached a problem that I've been struggling with for a while now. I was wondering if anyone had some advice on how to approach it (in particular part a) or some resources they could recommend to me?Thanks in advance, Sam
Hi Sam, and welcome to MHB!
I assume that $\|\mathbf x\|_1$ is defined as $\sum|x_j|$, where $x_j\ (1\leqslant j\leqslant n)$ are the coordinates of $\mathbf x$ with respect to some basis. It is not clear to me whether that basis is meant to be the given basis $\{\mathbf e_1,\ldots,\mathbf e_n\}$, or the standard basis for $\mathbb{R}^n$?
In the first of those two cases, define $$C = \max_{1\leqslant j\leqslant n}\|\mathbf e_j\|$$. Then $ \|\mathbf x\| = \left\| \sum x_j\mathbf e_j\right\| \leqslant \sum|x_j|\|\mathbf e_j\| \leqslant C\sum|x_j| = C\|\mathbf x\|_1.$ A similar proof will work if the norm $\|\mathbf x\|_1$ is defined with respect to some other basis (such as the standard basis).
Thanks for the response Opalg, it's good to be here.
You're right, ∥x∥1 is the 1-norm.
I don't understand the bit ∥x∥=∥∥∑xjej∥∥. Is this true for all norms? Sorry if the question sounds silly, I'm relatively new to the topic.
-Cheers, Sam
You are told that $\{\mathrm e_1,\ldots,\mathrm e_n\}$ is a basis. So every vector $\mathrm x$ can be (uniquely) written as a linear combination of the basis vectors: $\mathrm x = \sum x_j\mathrm e_j$. Then $\|\mathrm x\| = \left\|\sum x_j\mathrm e_j\right\|$. The next step is to use the triangle inequality to say that this is $\leqslant \sum|x_j|\|\mathrm e_j\|.$
SamJohannes said:
Any thoughts on part b?
Hi Sam,
To prove part (b), fix $\varepsilon > 0$; by continuity of $f$ at $(a,b)$, we can choose a $\delta > 0$ such that for all $(x,y)$, $||(x,y) - (a,b)|| < \delta$ implies $|f(x,y) - f(a,b)| < \varepsilon$.
Here's where I'll use the result of part (a). Let $\eta := \frac{\delta}{C}$, where $C$ is the constant in part (a). For all $x$, $|x - a| < \eta$ implies $||(x,b) - (a,b)||_1 = |x - a| < \eta$. So, $||(x,b) - (a,b)|| < C\eta = \delta$. Hence, $|f_b(x) - f_b(a)| = |f(x,b) - f(a,b)| < \varepsilon$. Since $\varepsilon$ was arbitrary, $f_b$ is continuous at $a$.
