Does the Equation of Motion Satisfy the Commutator Relation?
The discussion centers on demonstrating that the equation of motion for the density operator \(\rho(t) = \sum_a |\psi_a(t)\rangle P_a \langle\psi_a(t)|\) satisfies the commutator relation \(i\hbar\frac{\partial\rho(t)}{\partial t} = [H,\rho(t)]\). Participants clarify that the product rule is not applicable when the Hamiltonian \(H\) contains potential terms, emphasizing that \(H\) does not act as a simple derivative. The correct application of the product rule is crucial for deriving the relationship between the Hamiltonian and the time derivative of the density matrix.
  • Understanding of quantum mechanics, specifically the Schrödinger equation.
  • Familiarity with density operators and their mathematical representation.
  • Knowledge of commutator relations in quantum mechanics.
  • Basic grasp of operator algebra and product rules in calculus.
  • Study the implications of the Schrödinger equation on density operators.
  • Learn about the role of Hermitian operators in quantum mechanics.
  • Explore the derivation of the time evolution of density matrices in quantum systems.
  • Investigate the application of the product rule in operator calculus, particularly in quantum mechanics.
Quantum physicists, graduate students in physics, and anyone studying the dynamics of quantum systems and operator theory will benefit from this discussion.
jeebs
I have this density operator \rho(t) = \sum_a |\psi_a(t)\rangle P_a \langle\psi_a(t)| and I am supposed to be showing that "the equation of motion satisfies i\hbar\frac{\partial\rho(t)}{\partial t} = [H,\rho(t)].
I'm not making much progress though, this is all the info I'm given.
I'm thinking I have to use the product rule here, ie. \frac{\partial\rho(t)}{\partial t} = \sum_a (\frac{\partial}{\partial t}|\psi_a(t)\rangle) P_a \langle\psi_a(t)| + \sum_a |\psi_a(t)\rangle P_a \frac{\partial}{\partial t}\langle\psi_a(t)|
also if H = i\hbar\frac{\partial}{\partial t} then H\rho = i\hbar(\sum_a (\frac{\partial}{\partial t}|\psi_a(t)\rangle) P_a \langle\psi_a(t)| + \sum_a |\psi_a(t)\rangle P_a \frac{\partial}{\partial t}\langle\psi_a(t)|
and also I know the commutator is just [H,\rho] = H\rho - \rho H
so that gives me [H,\rho] = i\hbar(\sum_a (\frac{\partial}{\partial t}|\psi_a(t)\rangle) P_a \langle\psi_a(t)| + \sum_a |\psi_a(t)\rangle P_a \frac{\partial}{\partial t}\langle\psi_a(t)| - \sum_a |\psi_a(t)\rangle P_a \langle\psi_a(t)|i\hbar\frac{\partial}{\partial t}
but I can't see how I'm supposed to get any further. I mean, I don't see what's wrong with saying i\hbar\frac{\partial\rho}{\partial t} = H\rho. I don't see where the commutator comes from at all, unless for some reason we can say that \rho H = 0
If
<br /> H |\psi \rangle = i\hbar\frac{\partial}{\partial t} |\psi \rangle ,<br />
can you relate <br /> \frac{\partial}{\partial t} \langle \psi |
to an expression involving H?
Also, your expression for H\rho is incorrect. While \hat{H} is related to the time derivative by Schrödinger's equation, it doesn't itself act like a derivative.
\hat{H} (| \psi \rangle \langle \psi | ) = (\hat{H} | \psi \rangle ) \langle \psi |.
fzero said:
If
well if H |\psi \rangle = i\hbar\frac{\partial}{\partial t} |\psi \rangle
then \langle \psi |H^* = -i\hbar\frac{\partial}{\partial t} \langle \psi | = \langle \psi |H
since H is Hermitian? so
\frac{i}{\hbar}\langle \psi |H = \frac{\partial}{\partial t} \langle \psi |
i'll try and see where this gets me...
so you mean doing the product rule is incorrect?
if that is the case, then how do I get to use the \frac{\partial}{\partial t} \langle \psi | you suggested? how else would I get H acting on a bra?
Yes, if you have \hat{H} acting on a general object, the product rule is incorrect. The way to think about it is the following. A system is described by its Hamiltonian, which can be written as the operator \hat{H}. The particular kinetic term and potential tells us how the Hamiltonian acts on states and operators.
Now the quantum states of the system |\psi\rangle are solutions to the Schrödinger equation
\hat{H} |\psi\rangle = i \hbar \frac{\partial}{\partial t} |\psi\rangle . (*)
It's only on these states that the Hamiltonian has a representation as \hat{H} |\psi\rangle = i \hbar \partial/\partial t; in general it doesn't. The point of your problem is to obtain a relationship between the action of the Hamiltonian and the time derivative for the density matrix and it will be slightly more complicated than (*).
As for the conjugate state \langle \psi |, you obtain the conjugate version of (*) because |\psi\rangle is a solution to the SE.
actually I think I've got it but it did involve use of the product rule...
H\rho = \sum_a P_a H|\psi_a\rangle\langle \psi_a|
\rho H = \sum_a P_a |\psi_a\rangle\langle \psi_a|H
H\rho - \rho H = \sum_aP_a (H|\psi\rangle\langle \psi_a| - |\psi\rangle\langle \psi_a|H) = [H,\rho]
\frac{\partial}{\partial t}|\psi\rangle = \frac{-i}{\hbar}H|\psi\rangle
\frac{\partial}{\partial t}\langle \psi| = \frac{i}{\hbar}\langle\psi|H
i\hbar\frac{\partial \rho}{\partial t} = i\hbar\sum_aP_a(\frac{\partial}{\partial t}|\psi\rangle\langle \psi_a| + |\psi\rangle\frac{\partial}{\partial t}\langle \psi_a|) = i\hbar\sum_aP_a(\frac{-i}{\hbar}H|\psi\rangle\langle \psi_a| + |\psi\rangle\frac{i}{\hbar}\langle \psi_a|H) = \sum_aP_a (H|\psi\rangle\langle \psi_a| - |\psi\rangle\langle \psi_a|H) = [H,\rho]
So what's the lesson here? when I've got say, \frac{\partial}{\partial t}|\psi\rangle\langle\psi| I product rule it like (\frac{\partial}{\partial t}|\psi\rangle)\langle\psi| + |\psi\rangle\frac{\partial}{\partial t} \langle\psi| but when I've got an operator with a derivative in it, I only apply it to the thing directly to the right of it?
It's valid to use the product rule when the operator is a pure derivative. Hamiltonians generally have a potential term, for which the product rule is not valid. You can check this by representing
\hat{H} = - \hbar^2 \frac{\partial^2}{\partial x^2} + V
and acting on the product fg of some arbitrary functions f and g.
ahh, right, got it. cheers.
  • · Replies 32 ·
  • · Replies 0 ·
