Proving Cauchy Sequences with Cosine Function
8 replies · 3K views · last reply
Dollydaggerxo
Well, my problem is proving that sequences are in fact Cauchy sequences. I know all the conditions that need to be satisfied yet I cannot seem to apply it to questions. (Well, only the easy ones!)
My question is, prove that [tex]X_{n}[/tex] is a Cauchy sequence, given that [tex]X_{n+1}= f(X_{n})[/tex] where f(x)=cos(x).
I have been told that [tex]|X_{n+1}-X_{n}| \leq 2^{(1-n)}[/tex]
The attempt at a solution
Well basically, I tried using m,n>N and N>0 and m>n>N to say that
[tex]|X_m-X_n| = cos(X_{m-1}) - cos(X_{n-1})[/tex]
because this is the way i was doing it for simpler sequences.
However, I haven't got a clue where I would go from here which leads me to thinking I have gone the wrong way about it!
Any help would be greatly appreciated.
Thanks
OK, how do we prove that something is a Cauchy sequence?
First, a very mean man who hates undergrad analysis students is going to choose an [itex]\epsilon > 0[/itex]. What we have to do is, for whatever [itex]\epsilon[/itex] he chooses, be able provide a number N such that for any two numbers m and n that are both greater than N,
[tex]|{X_n - X_m}| < \epsilon[/tex].
If we can do this, then it's a Cauchy sequence.
So now it would be nice if we were able to do cool things with [itex]cos X_{m-1}[/itex], but I don't really see how that's going to help us. However, the inequality they told you about looks promising. Try to figure out a way to provide a number N in response to any [itex]\epsilon[/itex] using that inequality.
Hello, thanks for the reply.
Here is what I have done:
Take m,n>N
N>0
[tex]\epsilon > 0[/tex]
Take m = n+1 then
[tex]|X_m-X_n| \leq 2^{1-n} \leq 2^{-n}[/tex]
But then i don't know where to fit epsilon into it?
I actually have the answer in front of me, but it doesn't use epsilon at all, or N, which is what I have been used to using. So I wanted to see if there was a way to do it with them included.
What definition of Cauchy sequences are you using that doesn't contain an epsilon? Maybe there is some other variable used, like a lot of calculus textbooks now use "h" instead of [itex]\DELTA x[/itex] in the definition of a derivative?
In any event, you're not allowed to choose m and n; the inequality has to be true for ANY m and n which are both greater than N. Otherwise, you'd have the following (FLAWED) proof:
Let [itex]\{ x_n \} = \ln x[/itex]. Let [itex]m = n+1[/itex]. Then [itex]|X_m - X_n| = | \ln (n+1) - \ln n | = \ln \frac{n+1}{n}[/itex].
Now [itex]\lim_{n \rightarrow \infty} \ln \frac{n+1}{n} = 0.[/itex] Hence for any [itex]\epsilon[/itex], there is an N such that for n > N [itex]\ln \frac{n+1}{n}[/itex] < [itex]\epsilon[/itex]. So [itex]\{ x_n \}[/itex] is Cauchy.
Of course, this isn't true; ln x doesn't converge at all.
Yes I thought that was odd. But it is a follow on question so perhaps they had proved it before, I'm not sure.
But I want to be able to do it just based on this.
So I can't take m = n+1, that makes sense. I was just clutching at straws really, trying to use the inequality provided.
So could we take [tex]\epsilon > 0[/tex] and then we have [tex]|X_m-X_n| \leq 2^{1-n}[/tex]
but m,n>N, so if we take N > 1
[tex]|X_m-X_n| \leq 2^{1-n} \leq 2^{1-N} \leq 2^{-N}[/tex]
Is that wrong to just assume that?
Sorry, I am not very good at these at all! Thanks for your patience :)
You might try doing this.
Let [itex]\epsilon = .1[/itex].
Now give me N such that that no matter what m and n I choose greater than N, [itex]| X_m - X_n | < \epsilon[/itex].
Then try it for [itex]\epsilon = .001[/itex]. Then .00001, etc, until you get the method down.
Then generalize so that you can give me an N for any [itex]\epsilon[/itex] I choose.
Then in your proof, just write down the method of generating Ns in response to an [itex]\epsilon[/itex] and show that it makes [itex]| X_m - X_n | < \epsilon[/itex].
There will be a DIFFERENT N for each [itex]\epsilon[/itex], by the way. As [itex]\epsilon[/itex] gets smaller, N gets bigger.
you don't have to go back to the cauchy definition, perhaps it was proven somewhere that either
[tex]| a_{n} - a_{n+1} | \leq c^{n}[/tex] where |c| < 1
or
[tex]| a_{n} - a_{n+1} | \leq c^{-n}[/tex]
implies that the sequence is cauchy. In both cases, you can obviously see that as n gets large, c^n (where 0 < c < 1) or c^(-n) can be made arbitrarily small.
even if it was not proven formally anywhere, you can still use this
Okay that sort of makes sense, i have C defined in the set [-1,1] in a previous question. (if it is the same C !)
but what about the [tex]2^{n-1}[/tex]
where does that come in in terms of C ?
[tex]2^{1-n}[/tex] becomes small as n becomes large
