Proving Continuity of exp(x) at c=0
  • Thread starter Thread starter skoomafiend
    Continuity
1 reply · 2K views
skoomafiend
use delta, epsilon to prove that e^x is continuous at c = 0
(a) for y>0, lim_n-> inf, y^(1/n) = 1
(b) for x < y, exp(x) < exp(y)
im not sure how to approach this problem.
i have,
|exp(x) - exp(0)|= |exp(x) - 1|
so then exp(x) < 1 + ε
for δ > 0,
exp(δ) < 1 + ε
so then, i would set δ=ln(1+ε) for the proof?
also I am not sure how to use relevant eqn (a) to help with the problem. some insight would be appreciated. thank you.
You are not supposed to use log; you are supposed to use the two conditions (a) and (b); first you realize that the limit in (a) is fairly close to your limit, if you set y=e, then you can use that limit to come up with a delta which is a function of the N(epsilon) of that limit.
