Proving De Moivre's Theorem for Negative Numbers?
The discussion revolves around proving De Moivre's Theorem for negative integers, specifically addressing the challenges faced when extending the theorem beyond positive integers. Participants explore various approaches and mathematical manipulations related to complex numbers and their representations.
  • One participant successfully proves De Moivre's Theorem for positive integers but struggles to extend this proof to negative integers.
  • Another participant suggests using the relationship $$z^{-n} = (z^n)^{-1}$$ to facilitate the proof for negative integers.
  • Questions arise regarding the relationship between $$\frac{1}{\cis \theta}$$ and $$\cis (-\theta)$$, with some participants noting that they are equal but seeking a formal proof.
  • Concerns are expressed about the implications of raising a complex number to a power of -1 and how it affects the angle/argument in the context of De Moivre's Theorem.
  • Participants discuss the necessity of understanding the computation of $$\frac{1}{z}$$ in rectangular form to aid in the proof.
  • There is a suggestion that once the relationship between $$\frac{1}{\cis \theta}$$ and $$\cis (-\theta)$$ is established, it could simplify the transformation of the theorem for negative integers.
Participants express a lack of consensus on how to formally prove the theorem for negative integers, with multiple approaches and ideas being proposed but no definitive resolution reached.
Participants highlight the challenge of manipulating complex numbers and the need for a clear understanding of the relationships between their forms, particularly when transitioning from positive to negative integers.
NatFex
Or basically anything that isn't a positive integer.
So I can prove quite easily by induction that for any integer n>0, De Moivre's Theorem (below) holds.
If ##\DeclareMathOperator\cis{cis} z = r\cis\theta, z^n= r^n\cis(n\theta)##
My proof below:
Let P(n) be the statement ##z^n = r^n\cis(n\theta)##
Prove true for n = 1:
##z^1 = z = r\cis\theta = r^1\cis(1\theta)##
Assume true for n = k:
##z^k = r^k\cis(k\theta)##
Prove true for n = k + 1:
##z^{k+1} = z^k \times z\\
= r^k\cis(k\theta) * r\cis\theta\\
= r^{k+1}\cis(k\theta)\cis\theta\\
= r^{k+1}(\cos(k\theta) + i\sin(k\theta))((\cos\theta + i\sin\theta)\\
= r^{k+1}(\cos(k\theta)\cos\theta + \cos(k\theta)i\sin\theta + i\sin(k\theta)\cos\theta - \sin(k\theta)\sin\theta)##
then by compound angle identities
##= r^{k+1}(\cos(k\theta + \theta) + i\sin(k\theta + \theta))\\
= r^{k+1}\cis((k+1)\theta)##
However I struggle to do this with negatives. I tried the simple case of
##\frac{1}{r\cis\theta}## and from there, try to get to ##\frac{1}{r}\cis(-\theta)##, but I've only managed to do that by replacing the numerator of 1 with ##r\cis0##, which is equivalent, and then from there using De Moivre's Theorem to get an argument of ##-\theta##, which is... not very useful considering De Moivre's Theorem is what I'm trying to prove in the first place.
I just can't manipulate it into a form that would allow me to use compound angle identities like I could with positive numbers. Any ideas?
Mathematics news on Phys.org
You can use $$z^{-n} = (z^n)^{-1}$$
What is the relation between ##\frac{1}{\cis \theta}## and ##\cis (-\theta)##?
Math_QED said:
You can use $$z^n = (z^n)^-1$$
Yeah, but I can't prove that that last step (raising the complex number to a power of -1) will make the angle/argument inside ##\cis## negative
I know that ##\frac{1}{r\cis\theta} = (r\cis\theta)^{-1}##, but -1 is outside the boundaries for n that I have proved in my first post :(
I know it works, I would just like to prove it.
What is $$1/z$$ equal to?
So what?
Where in your proof for positive ##n## did it matter whether the angle is positive or negative?
You didn't answer the question: what is the relation between ##\frac{1}{\cis \theta}## and ##\cis (-\theta)##?
##z^{-1}##, but my proof in the OP only works for positive integers. I'm trying to use -1 as a base case to write a proof for negative numbers, but for some reason I cannot work out how to apply a similar strategy (expand then use compound identities)
Samy_A said:
So what?
It doesn't matter if θ is positive or negative, what matters is its multiplier, which is n.
Well... they are equal, but thus far my understanding of it is only intuitive, until I can prove it, which is what I'm asking for help with
Ok, so if ##z=a+ib##, where ##a, b## are real, how would you compute ##\frac{1}{z}=\frac{1}{a+ib}##?
Hint: multiply numerator and denominator by ##a-ib##.
Once you have proven that ##\frac{1}{\cis \theta}=\cis (-\theta)##, you can easily transform the formula with a negative ##n## into a formula with the positive ##-n##. And then you can use what you already have proven.
Brilliant, just what I was looking for
I completely forgot about looking at the complex numbers in rectangular form instead, cheers!
  • · Replies 105 ·
12K
  • · Replies 35 ·
