Proving determinant formula using permutation definition
27 replies · 5K views · last reply
bon
Ok so please see question in attachment
Not sure how to solve it..
I'm meant to be using the general defn of determinant as sum over all permutations of sgn(p) A1P(1)...AnP(n)
so i see that det A = sum over all permutations of sgn(p) A1P(1)...AjP(j)..AnP(n)
for P(j) = k, but i don't really see how to simplify this into the form they want..
help please :)?
for P(j) = k
I just don't see how to simplify this further :( ..
lambda bj + u cj
So i can bring that to the front of the product..
hmm then i can't see how to progress again :(
So you have that
[tex]A_{1,P(1)}...A_{k,P(k)}...A_{n,P(n)} = \lambda A_{1,P(1)}...B_{k,P(k)}...A_{n,P(n)}+\mu A_{1,P(1)}...C_{k,P(k)}...A_{n,P(n)}[/tex]
Now this is equal to
[tex]B_{1,P(1)}...B_{k,P(k)}...B_{n,P(n)}+\mu C_{1,P(1)}...C_{k,P(k)}...C_{n,P(n)}[/tex]
Sum this, and you've got what your looking for...
I've actually decided i still don't understand :(
Now AjP(j) = lambda Bjk + u Cjk
so det A = sum over all permutations of sgn(p) A1P(1)...lambda Bjk+u Cjk..AnP(n)
But then how do i sum and simplify?
micromass said:
So you have that
sorry, thought id quote you again, so you'd see my response...
So what step of my proof don't you get?
Do you see why
[tex]A_{1,P(1)}...A_{k,P(k)}...A_{n,P(n)}= \lambdaA_{1,P(1)}...B_{k,P(k)}...A_{n,P(n)}+\mu A_{1,P(1)}...C_{k,P(k)}...A_{n,P(n)}[/tex]
if P(k)=j??
Do you see why it suffices to show the hint? (every permutation can be written as a product of transpositions)
So it just suffices to prove the theorem for J=(n k). Let's take the case J=(1 2) (thus J is the permutation which switches 1 and 2.
We have to calculate
[tex]\det(A^\prime_P)=\sum_{Q}{A^\prime_{1,Q(1)}A^\prime_{2,Q(2)}...A^\prime_{n,Q(n)}}[/tex]
We know that [tex]A^\prime_{j,k}=A_{j,P^{-1}(k)}[/tex].
Can you use this in the formula of the determinant?
I think i get the hint..is it because a permutation that differs by two pair exchanges has sgnP = 1 and three pair exhanges has sgnP = -1 which is the same as one pair exhange..?
Im not sure i do get it actually..
and don't see what J is in your explanation above..
also surely in your expression for det A'p, you've left out sgnQ?
confused :S
Yes, how silly of me, I left out sgn(Q). The permutation P is just the one that switches 1 and 2 and leaves the rest fixed. I mean:
[tex]P(1)=2, P(2)=1, P(x)=x~\text{if}~1\neq x\neq 2[/tex]
So, I say you can express A' as
[tex]A^\prime_{i,j}=A_{i,P^{-1}(j)}[/tex]
This is basically the definition of A', do you see that?
Now we have to calculate
[tex]\det(A^\prime)=\sum_{Q}{sgn(Q)A^\prime_{1,Q(1)}...A^\prime_{n,Q(n)}}[/tex]
Can you now change every instance of [tex]A^\prime_{j,Q(j)}[/tex] into an instance of the matrix A?
Thanks. I'll have a go :)
Just wanted to ask if you could try to explain why the hint works to me clearly..i tried to explain it above but am kind of confusing myself..
sorry to keep bothering you
So i get det A' = sum over all Q of sgn(Q) A 1 p^-1(Q(1))...A n P^-1(Q(n)).
I guess this is right? where to go from here? :S ahh i hate this topic :P
OK, now instead of summing over Q, you can sum over [tex]P^{-1}Q[/tex]. Then you still got every permutation, so you've got (if [tex]Q^\prime=P^{-1}Q[/tex] ):
[tex]\sum_{Q^\prime}{sgn(Q)A_{1,Q^\prime(1)}...A_{n,Q^\prime(n)}}[/tex]
This looks a lot like the formula of the determinant. Only sgn(Q) is bothering us. Can you change Q in a term containing only P and Q'? If you did that, then you just got to use that
[tex]sgn(PQ')=sgn(P)sgn(Q')[/tex]
And then you've got it. This way it doesn't use the hint, so don't worry if you don't understand that...
Well, if you really want to know the hint. Do you know what the notation e.g. (1 2)(1 2 3) means?
And don't worry about bothering me, you're not :smile:
Thanks a LOT! I do get it now, but would still like to get the hint... I don't know the notation, no. :(
Hmm, explaining the hint is quite troublesome if you don't know that notation.
A transposition is a permutation which simply exchanges two elements. The hint simply says that every permutation can be written as a composition of transpositions. But proving this asks a little work.
Hmm okay thanks!
The final question now asks me to prove det(AB) = det (A) det (B)
It says that i have to use the previous two results..(which I've asked about)
the hint is to express the comumn vectors of AB as liear combinations of the column vectors of the matrix A..
So i know that (AB)ij = AikBkj but i don't see how to express the columns of AB in terms of column vectors of matrix A
Hmmm, that's suddenly a lot harder...
Here's a sketch. (HINT: write this out first in the case n=2, so you see what happens)
First of all let [tex]A=(A_1 ... A_n)[/tex]. Check first that
[tex]AB=(\sum_{k_1=1}^n{b_{k_1,1}A_{k_1}} \sum_{k_2=1}^n{b_{k_2,2}A_{k_2}} ... \sum_{k_n=1}^n{b_{k_n,n}A_{k_n}} )[/tex]
Dont worry about the indices k1 to kn, I just wanted other indices for every sum...
So take the determinant from this. You have proved that determinants are multilinear, thus this gives us
[tex]\det{AB}=\sum_{k_1,...,k_n=1}^n{b_{k_1,1}...b_{k_n,n}\det(A_{k_1}...A_{k_n})}[/tex]
Now, a lot of these terms become zero. In fact if any of the [tex]k_i[/tex] equals any of the [tex]k_j[/tex], then the determinant [tex]\det(A_{k_1} ... A_{k_n})[/tex] becomes zero. So we can assume that all the [tex]k_i[/tex] are unequal. But then there exists a permutation P, such that [tex]P(i)=k_{i}[/tex]. So we can write the above sum as
[tex]\det{AB}=\sum_{P} {b_{P(1),1}... b_{P(n),n}\det(A_{P(1)},...,A_{P(n)})}[/tex]
Now use the other fact you've proven, and you've got it...
