Proving Equation (1): Let r(t) be a Vector in $\mathbb{R^3}$
  • Topic:
  • Thread starter Thread starter WMDhamnekar
    Vector
2 replies · 2K views
WMDhamnekar
MHB
Let r(t) be the position vector for a particle moving in $\mathbb{R^3}.$ How to show that
$$\frac{d}{dt}(r \times (v\times r))=||r||^2 *a+ (r\cdot v)*v-(||v||^2+ r\cdot a)*r \tag{1}$$
Where r(t) is a position vector (x(t),y(t),z(t)), $v(t)=\frac{dr}{dt}=(x'(t),y'(t),z'(t)), a(t)=\frac{dv}{dt}=\frac{d^2r}{dt^2}=(x''(t),y''(t),z''(t))$ Note: v=velocity, a= acceleration
My attempt:-
I know $\frac{d}{dt}(f\times g)=\frac{df}{dt}\times g +f\times \frac{dg}{dt}$. I also know for any vectors u, v, w in $\mathbb{R^3}, u\times (v\times w)=(u\cdot w)*v-(u\cdot v)*w $
But I don't understand how to use these formulas to prove equation (1)?
If any member knows answer to this question may reply with correct answer.
Hi Dhamnekar,
You're correct that those two formulas need to be used, nicely done. I will start the computation below. See if you can finish it. If not, I'm happy to answer any other questions you may have. Note: I will use the dot notation to denote a derivative with respect to time.
\begin{align*}
\frac{d}{dt}(r\times (v\times r)) &= \dot{r}\times (v\times r) + r\times \dot{(v\times r)}\\
& = v\times (v\times r) + r\times (\dot{v}\times r + v\times\dot{r})\\
& = v\times (v\times r) + r\times (a\times r + v\times v)
\end{align*}
Can you proceed from here? Hint: $x\cdot x = \| x\|^{2}.$
[math]\textbf{a} \times ( \textbf{b} \times \textbf{c} ) = ( \textbf{a} \cdot \textbf{c} ) \textbf{b} + ( \textbf{a} \cdot \textbf{b} ) \textbf{[/math]
My attempt:-
Is this a part of a derivation? The [math]\textbf{r} \times ( \textbf{v} \times \textbf{r} )[/math] looks familiar but I can't seem to find it.
-Dan
