Proving exp function is bounded and not extended continuously.
  • Thread starter Thread starter cookiesyum
    Bounded Function
6 replies · 3K views
cookiesyum
The function
exp[ (x2 + y2 - xy)/(x2 + y2) ] = f(x,y)
is continuous on the open first quadrant.
Prove it is bounded there.
Prove f cannot be extended continuously to the closed first quadrant.
Since f is a real-valued function defined and continuous on a compact set (open first quadrant...I think...), then f is bounded..? So I have to show that the open first quadrant is a compact set maybe?
I think I have to show that f is not uniformly continuous on the closed first quadrant. So, there exists an epsilon > 0 where a number d >0 cannot be found such that |f(p) - f(q)| < epsilon whenever p and q are in the closed first quadrant and |p-q|<d.
I have so much trouble starting my proofs properly. I don't know how to set them up at the beginning, even when I know the rough outline.
on Phys.org
You need to check your definition of compact.
can you bound the rational function on the open first quadrant?
Try working with this expression:
[tex]\frac{x^2 + y^2 - xy}{x^2 + y^2}[/tex]
I can't give you much more of a hint than that without essentially doing the problem.
|(x2 + y2 - xy)/(x2 + y2)| = |(r2 - rcosArsinA)/r2)| = |1-cosAsinA| which is bounded by 0 and 1
So f(x,y) is bounded by 1 and e.
Is it enough to show that? Or do I need to use definition of limits...
Also, for the second part, it cannot be extended because x=0=y is a singularity. Does it suffice just to say that or does that not count as a full proof?
You don't need to convert to polar form. How did you conclude that f(x, y) is bounded by 1 and e? Are you saying that all values of f(x, y) on the open first quadrant are between 1 and e? That's not true.
Think division.
Think division.
Ok let me try this again...
|(x2 + y2 - xy)/(x2 + y2)|<or= 1 because you are subtracting xy from the top so something smaller divided by something larger is a fraction less than one.
Then, since the exponent is bounded by m=1, can you say f(x,y) is bounded by 0 and e, i.e. when you plug in 1 in the exponent you get e^1 = e?
For the second part, I THOUGHT I could use the discontinuity x=y=0 but since S is the open first quadrant, can I do that?
