Proving Inequality for Complex Numbers with Absolute Value Constraints
20 replies · 5K views · last reply
Brunno
Hi fellows,
Prove that:
[tex]\sqrt{\frac{7}{2}}[/tex][tex]\leq[/tex]|z+1|+|1-z+z²|[tex]\leq[/tex][tex]\sqrt{\frac{7}{6}}[/tex]
for all complex numbers with |z|=1.
I've tried something like this:
Starting by the following property:
-|z|[tex]\leq[/tex]Re(z)[tex]\leq[/tex]|z|
but i could'nt get anywhere.
Thanks in advance.
Have you tried squaring both sides of the inequality?
Yes:
7/2<= |t²+2tu+u²|<=63/6
But from here i can't go anywhere.I don't know from where to start to prove it.:(
where t=(z+1) and u=(1-z+z²)
Hi Brunno! :smile:
I can't see a neat way of doing it :redface:
You could try putting z = cosθ + isinθ, z2 = cos2θ + isin2θ.
Or maybe use 1 - z + z2 = (1 + z3)/(1 + z).
(I haven't tried either of them)
Hi,
I tried the second one but still doesn't seem to make it easier.How to solve it by the non neat way?
This is a relatively minor point, but the direction of your inequalities is going the wrong way. For one thing you are saying that sqrt(7/2) <= sqrt(7/6), which isn't true.
Also, your inequality will look better if you use just a single pair of tex and /tex tags.
Here's your inequality in cleaned up form, with the correction noted above.
[tex]\sqrt{\frac{7}{6}} \leq |z+1|+|1-z+z^2| \leq \sqrt{\frac{7}{2}}[/tex]
Click the inequality to see what my LaTeX script looks like.
Mark44,thanks.I didn't notice it.Yes it's not sqrt(7/6) but actually 3sqrt(7/6).
Brunno said:
Yes:
That "t2+2tu+u2" is better written in terms of z as...
(z2+2)2
That might also make it easier.
So it should be something like:
7/2<=(z²+2)²<=63/6
I still can't see any further...:cry:
Brunno said:
HeLLLLP People!:)
Well, there's a few things wrong with the above.
For starters, |t²+2tu+u²| is not correct. It should be |t|²+2|tu|+|u|².
This makes (z²+2)² the wrong direction to take.
I've simply tried to fill in a couple of values for z.
With z = 1, we get |z+1|+|1-z+z²| = 3 > sqrt(7/2)
This is out-of-range, so the conclusion is that the original statement is false.
Qed.
Qed.
This is incorrect. Looks like you missed post #8:
So
[tex]\sqrt{\frac{7}{2}} \leq |z+1|+|1-z+z^2| \leq 3\sqrt{\frac{7}{6}}[/tex]
is the correct inequality, and if you substitute in z = 1 the inequality holds.
So
True, I missed that one. Thanks for the correction.
I've gone on and filled in a few more numbers (since the equation is oddly difficult to solve).
Code:
arg z   (|z+1|+|1-z+z²|)²
π/3       3                        < 7/2
5π/6     10.56                     > 3² . 7/6 = 21/2
Again I find numbers that are out-of-range on both sides of the equation.
Did I miss something else?
Btw, I used Excel to find these numbers, which must be close to the minimum and maximum values.
[EDIT]Here's the graph I plotted
[/EDIT]
lurflurf said:
That should not be (5π/6,10.56), but rather (2Arccos(1/4),10.5625).
So how did you find it?
I've verified it with WolframMathematica (cool site :cool:)!
I'm concluding that the equation should be:
[tex]\sqrt 3 \leq |z+1|+|1-z+z^2| \leq \frac {13} {4}[/tex]
I've solved this by taking the square, deriving it to phi, and setting the result to zero:
http://www.wolframalpha.com/input/?...sin(2x)+-+6+sin(3x)+/+sqrt(2+++2+cos(3x))+=+0
It finds the solutions 0 and 4 arctan sqrt(3/5).
Checking some more teaches me that 4 arctan sqrt(3/5) = 2 arccos 1/4 = 2 arctan sqrt 15.
Checking out pi and pi/3 learns that they are solutions as well.
So we have the following extrema:
[tex]\begin{matrix}<br /> z & |z+1|+|1-z+z^2| \\<br /> \hline<br /> 1 & 2 \\<br /> \pm \frac \pi 3 & \sqrt 3 \\<br /> \pm 2 \arccos \frac 1 4 & \frac {13} 4 \\<br /> \pi & 3 \end{matrix}[/tex]
let t=arg(z) with the usual convention -pi<t<=pi then by elementary trigonometry
|z+1|+|z^2-z+1|=a[2 cos(t/2)+(1/2)a]^2-(13/4)a
where
a=-1 when |t|=<pi/2
a= 1 when |t|>=pi/2
there will be local extrema when
2 cos(t/2)=0 ->t=0
a changes ->|t|=pi/3
2 cos(t/2)=1/2 ->|t|=2 Arccos(1/4)
2 cos(t/2)=1 ->t=pi
where
a=-1 when |t|=<pi/2
a= 1 when |t|>=pi/2
2 cos(t/2)=0 ->t=0
2 cos(t/2)=1 ->t=pi
Nice solution!
I feel stupid for not seeing it myself.
