Proving Isomorphism of Fields with Four Elements
  • Thread starter Thread starter Bashyboy
    Elements Field
3 replies · 3K views
Bashyboy
Show that any two Fields with four elements are isomorphic.
Let ##F= \{0,1,a,b\}## be a field with four elements. Since ##F## is an additive abelian group, by Lagrange's theorem ##1## must have either an order of ##2## or ##4##; i.e., either ##1+1=0## or ##1+1+1+1=0##. Since ##F## is a field, every nonzero element is a unit, meaning that the group of units ##U(F)## is a group of ##3## which makes it isomorphic to ##\Bbb{Z}_3##. Note that neither ##a+b=a## nor ##a+b=b## can hold. This leaves us with ##a+b = 0## or ##a+b=1##...This is where I get stuck. I am trying to show that ##1+1 = 0##. If I can rule out ##a+b=1##, then I can show ##b=-a##, and therefore ##(-a)^3 = 1## or ##-1=1## or ##1+1=0##. Another route is to assume that ##1+1+1+1=0## is true, which would imply ##F \simeq \Bbb{Z}_4##, and then deduce a contradiction, but I haven't been able to identify the contradiction. Perhaps there is a problem with ##F \simeq \Bbb{Z}_4## and ##U(F) \simeq \Bbb{Z}_3## being simultaneously true...I could use some guidance.
Okay. So ##(1+1)^2 = (1+1)(1+1) = 1 + 1 + 1 + 1 = 0##. Since we are working in a field there can be no nonzero divisors which means ##1+1=0##.
Would this be another valid way of proving the claim? Suppose that ##a+b \neq 0##. This means that ##a+b \in U(F) \simeq \Bbb{Z}_3##, which implies that ##(a+b)^3 = 1## or ##1 + 3a^2b + 3a b^2 = 0##. Multiplying by ##a## and then ##b## yields the equations ##a + 3b + 3a^2 b^2 = 0## and ##b + 3a^2 b^2 + 3a = 0##, and adding the two gives ##4a + 4b + 6a^2 b^2 = 0## or ##6a^2 b^2 = 0##, which is a contradiction since neither ##a=0## nor ##b=0##. Hence ##a + b = 0## or ##b = -a##. Then ##(-a)^3 = 1## implies ##-1 = 1##.
Admittedly it is a bit longer, but somewhat interesting, although it may be invalid/unsound.
How do you justify the implicit assumption that [itex]6 \neq 0[/itex]?
It is in fact true that [itex]a + b = 1[/itex]: it follows from [itex]1 + 1 = 0[/itex] and the field axioms.
