Proving Limit with Epsilon and Delta
The discussion revolves around proving the convergence of the sequence an = n²/(2n²+n-1) to L = 1/2 using the epsilon-delta definition. Participants suggest simplifying the expression |an - L| to facilitate finding an appropriate N such that |an - L| < ε for n ≥ N. They recommend estimating the expression with simpler bounds to make it easier to establish convergence. A key point is ensuring that the chosen N is large enough to satisfy the inequality for any ε > 0. The conversation emphasizes the importance of bounding the sequence effectively to demonstrate its convergence.
msell2
Prove the following sequence {an} converges to L=1/2
an = n2/(2n2+n-1)
Given ε>0 we can determine an N∈N so that |an - L|<ε for n≥N. We have:
|an-L|=|(n2/(2n2+n-1)-(1/2)|
= |(-n+1)/(2(2n-1)(n+1))|
I'm not sure what to do once I get to this point. Any help would be great!
an = n2/(2n2+n-1)
If you change the numerator to (+n+1) you can get that fraction to be less or equal to$$
\frac 1 {2(2n-1)}$$What happens if you drop the ##-1## too?
[Edit] Ignore the drop the -1 part. Maybe change the -1 to -n?
In a similar vein, you might want to show that ##0<\frac{n-1}{2(2n-1)}<1## for n>1.
The point behind these ideas is that it can be difficult to find N for a given ε unless the expression is quite simple, so you estimate the expression you have with something simpler.
E.g. suppose you wanted to show that 1/(n^2 + 6) -> 0. One way to do this is to note that:
0 < 1/(n^2+6) < 1/n
So, you can take N = 1/ε. Which is much simpler than trying to find a more precise N for the original sequence.
For your example, you want to find a simple expression that is greater than the one you have but still -> 0. That's the strategy, anyway. (See Vela's idea for how to do this.)
Thanks for the help! Does this look right?
Given ε>0 we can determine an N\inN so that |an-L|<ε for n≥N. We have:
|an-L|=|\frac{n^{2}}{2n^{2}+n-1}-\frac{1}{2}|=|\frac{2n^{2}}{2(2n^{2}+n-1}-\frac{2n^{2}+n-1}{2(2n^{2}+n-1}|=|\frac{-n+1}{2(2n^{2}+n-1}|=|\frac{-n+1}{2(2n-1)(n+1)}|<ε.
Now take \frac{n-1}{2(2n-1)}. Since n-1>1 when n>1 and since 4n-2 > n-1 > 1 \Rightarrow 0<\frac{n-1}{2(2n-1)}<1 when n>1. As long as we have n>1, we have that |\frac{-n+1}{2(2n-1)(n+1)}|<\frac{n-1}{2(2n-1)}. We want to bound this by ε>0. Take ε>0. If we choose N to be the smallest integer greater than or equal to max{1,1/ε} then we have that, for n≥N:
|\frac{n^{2}}{2n^{2}+n-1}-\frac{1}{2}|<\frac{1}{n}<\frac{1}{N}≤ε
where the last line follows directly if N≥1/ε and is also satisfied for N=1>1/ε since this implies 1/N<ε.
Is that last inequality what you intended?
What is wrong with that inequality?
How are you going from
msell2 said:
\lvert \frac{-n+1}{2(2n-1)(n+1)} \rvert &lt; \frac{n-1}{2(2n-1)}
to
\lvert \frac{n^{2}}{2n^{2}+n-1}-\frac{1}{2}\rvert &lt; \frac{1}{n} &lt; \frac{1}{N}≤\varepsilon
n-1< 4n -2 => 1<3n which is true for n>1 get it?
