Proving ln(x^2+y^2) is a Potential Function
7 replies · 2K views · last reply
bugatti79
Show that ln(x^2+y^2) is a potential function for the following vector field
[itex]\displaystyle \frac{2x \vec i}{(x^2+y^2)^{1/2}} +\frac{2y \vec j}{(x^2+y^2)^{1/2}}[/itex]
I calculate [itex]\nabla \phi[/itex] as
[itex]\displaystyle \frac{2y^2}{(x^2+y^2)^{3/2}} \vec i +\frac{2x^2}{(x^2+y^2)^{3/2}} \vec j[/itex]
I don't know how this connects to the log function...?
Thanks
Thanks
It doesn't because you have calculated it incorrectly. ##\nabla f = \langle f_x, f_y\rangle##. Is that what you did?
I just took the gradient
[itex]\displaystyle \nabla \phi =\frac{\partial}{\partial x} \frac{2x \vec i}{\sqrt {x^2+y^2}}+\frac{\partial}{\partial y} \frac{2y \vec j}{\sqrt{ x^2+y^2}}[/itex]..?
You were supposed to show that ##\phi(x,y) = \ln{(x^2+y^2)}## is a potential function for your vector field. ##\phi## is what you should be taking the gradient of.
Thanks
To find the potential function, set [tex]f_{x}=\frac{2x \vec i}{(x^2+y^2)^{1/2}}[/tex]Then take the integral w.r.t. x. which then rewrite f(x,y)=...+g(y). Then take the derivative of this w.r.t. y and equate it to the second one. Then f(x,y), the potential function satisfies the vector field.
Thanks, noted.
Then I calculate this, I don't know where the sqrt comes into it unless its a typo in the question?
[itex]\displaystyle \frac{2y}{x^2+y^2} \vec j +\frac{2x}{x^2+y^2} \vec i[/itex]
bugatti79 said:
Thanks, noted.
This is what I get also.
It looks like the correct potential for that vector field is [itex]\displaystyle \phi(x,\ y)=-2\sqrt{x^2+y^2}+C[/itex]
V. good.
Thank you SammyS.
