Proving Nabla-Cross(A x B) Equation
  • Thread starter Thread starter rado5
10 replies · 4K views
rado5
Prove that [tex]\nabla\times(A\times B)= (B.\nabla)A-(A.\nabla)B-B(\nabla.A)+A(\nabla.B)[/tex]
bac-cab [tex]\nabla\times(A\times B)= (\nabla.B)A-(\nabla.A)B[/tex]
I know that [tex]B(\nabla.A)=(\nabla.A)B[/tex] and [tex]A(\nabla.B)= (\nabla.B)A[/tex]
So what about [tex](B.\nabla)A-(A.\nabla)B=?[/tex] Does it equal to zero? Or maybe bac cab is not related to this problem!
When and how is this ["bac - cab"] equation valid? The above equation is valid only as long as "a" is...?
So how can I prove it? Please help me!
Prove it by letting [itex]\vec A = \langle f,g,h\rangle,\ \vec B = \langle u,v,w\rangle[/itex] and just work out both sides to check they are equal. It's easy, just a little algebra.
Another interesting way would be to do to use a gem of a trick that I learned off of the Feynman Lectures. Refer to Feynman Lectures, Volume II, Lecture 27, Field Energy and Field Momentum.
Thank you very much for your help. I actually proved it in the way you suggested me, but only for the x-component, and it was a lot of algebra!
Thank you very much. I will try to study it.
Do you know index notation? Vector identities are quite easy with it.
http://www.physics.ucsb.edu/~physCS33/spring2009/index-notation.pdf
Give this a try. Unfortunately, when I learned it, it was during lectures and not in our textbook so I can't tell you what book you can learn it out of. This should be enough though.
Thank you very much. I downloaded it and I will read it.
