Proving Parallel Isothermal Lines: No Pressure/Volume Values Given
  • Thread starter Thread starter Ne0
    Thermodynamic
The discussion revolves around proving the relationship between isothermal lines on a P-V graph for a gas, specifically addressing whether these lines are parallel when no specific pressure or volume values are provided. Participants reference the ideal gas law and the characteristics of isotherms, which are described as hyperbolas in this context.
  • Participants explore the implications of the ideal gas law, questioning how to demonstrate that isotherms do not intersect and whether they can be considered parallel. There are discussions about the slopes of the isotherms and the conditions under which they might be compared.
Some participants have suggested methods for analyzing the slopes of isotherms and have noted that a contradiction argument could be used to show that the isotherms do not intersect. Others are still seeking clarity on the definitions and implications of parallelism in this context.
There is a lack of consensus on the interpretation of parallel isotherms, with some participants questioning the validity of describing curves as parallel and discussing the implications of temperature differences on the behavior of the isotherms.
Ne0
Dealing with isothermal lines. How would you go about proving if the two lines are parallel if no values are given for the Pressure or the Volume?
This is what I've got so far:
Q = -W
dU = 0, where U is internal energy.
P1V1 = nRT
P2V2 = nRT
P1V1=P2V2
Or:
P1/P2 = nRT1 / nRT2
The problem is I don't know how to start showing that the lines don't cross, i.e. the slopes are the same. Any help is greatly appreciated. Thank you.
Q = -W
P1V1 = nRT
P2V2 = nRT
P1V1=P2V2
Or:
P1/P2 = nRT1 / nRT2
strange.
on a P-v graph, isotherms are rectangular hyperbolas. (look like 1/x.)
they are only straight lines on a T-P or T-V graph (or a T-s graph, if you're there yet), in which case it's pretty obvious that all isotherms will be parallel.
i'm not even sure of what your question is asking, though.
I am working with Ne0 on this problem.
When he says line, he means hyperbola.
We need to show that the graphs of two isotherms on a P-V graph for the same gas at two different temperatures are parallel.
I hope this makes it a little more clear.
i didn't even know that you could say that a curve is parallel to another one!
does that mean that the tangent lines have the same slopes at the same value of V or P or something?
i don't think i can help. sorry. :/
Skorch and Ne0,
I'm still not sure exactly what you want, but let me just throw some things out that you may find helpful. You can calculate the slope of various isotherms easily enough from the ideal gas law. Temperature appears explicitly in the result, but you can use the ideal gas law to reexpress the answer in terms of P and V only. It is then a simple matter to figure out the set of all the points (P,V) with a given slope.
I think they're trying to get at the fact
that two isotherms don't intersect on
a P-V diagram.
if they did you'd have a system with
a single coordinate (P, V)
giving rise to two different temperatures.
Yes we are trying to prove using the ideal gas law that the two isotherm lines never intersect just like Gbert mentioned. I was thinking of maybe differentiating for PV=nRT and somehow show that the two isotherms have the same slope.
I was thinking like one point on an isothem to be (V1,P1) and another point (V2,P2) and the slope would be, P=nrt/V, (nRT/V2-nrt/V1)/(V2-V1). I am not quite sure what to do with this result because we need to somehow show from the other isothem that they are identical and therefore will never intersect. Another idea I was thinking of was differentiating PV=nrT and maybe from there show that they are the same for the two isotherms. I got VdP + PdV = nRdT but from there I am not quite sure of how to show they are the same.
If all you want to do is prove they don't intersect, you can do it by a simple contradiction argument.
Let's say one isotherm is defined by PV = nRT_1
and the other is defined by PV = nRT_2 on a standard P vs V plot. T_1 and T_2 are distinct (unequal).
Let us start of by making the assumption some intersection point exists.
At that intersection point, the P and V values are identical, hence so is the product PV, so at that point nRT_1 = nRT_2 giving T_1 = T_2
But that's an impossibility since T_1 and T_2 were *defined* to be unequal. Hence a contradiction has been arrived at meaning the original assumption of an intersection is false.
Bit wordy, but that's a formal proof if you're looking for it.
The two isotherms are not parallel but, as Curious has shown, they do not intersect.
To show that they are not parallel, draw two arbitrary horizontal lines between them. These represent lines where P=constant. If they are parallel isotherms, these isobars would be the same length (the length representing change in volume). The change in volume of the gas along each isobar
[tex}V_1 = nRT_1/P[/tex]
[tex}V_2 = nRT_2/P[/tex]
V_2 - V_1 = \frac{nR}{P}(T_2-T_1)
which is not constant for all P.
AM
