Proving Subspace Intersection and Finite Linear Combinations in Vector Spaces
The discussion revolves around proving properties of subspaces in vector spaces, specifically focusing on the intersection of multiple subspaces and the relationship between a set of vectors and their span. Participants are exploring the definitions and characteristics of subspaces in the context of linear algebra.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to prove that the intersection of subspaces is itself a subspace and explore the relationship between a set of vectors and their span. Questions arise about how to demonstrate that the intersection contains only finite linear combinations of the vectors from the set.
Some participants have made progress in understanding the relationship between the intersection of subspaces and the span of a set of vectors. There is an ongoing exploration of how to formally prove the containment relationships between these sets, with hints and partial insights being shared.
Participants note the challenge of proving the properties without assuming prior knowledge of theorems, and there is mention of a theorem regarding the smallest subspace containing a set of vectors, which is relevant to the discussion.
sakodo
Let V be a vector space over the field K.
a) Let {[tex]W_{k}:\ 1\leq k \leq m[/tex]} be m subspaces of V, and let W be the intersection of these m subspaces. Prove that W is a subspace of V.
b) Let S be any set of vectors in V, and let W be the intersection of all subspaces of V which contains S (that is, x E W if and only if x lies in every subspace which contains S). Prove that W is the set of finite linear combinations of vectors from S.
a) I got this part so I will skip this. Part b is where I am stuck at. Just assume W is a subspace of V.
b) From what I understand, the question wants me to prove that W=span of S. I seriously don't know what to do. I tried to prove that any vectors that are NOT the span of S cannot be in W, but I didn't know where to go from there.
From a book I read, b) is actually a theorem. It says "W is the smallest subspace of V that contains S" but unfortunately it doesn't show any proofs for it.
I feel like I have missed something. Any hints?
Any help would be appreciated.
Show W is contained in span(S), and span(S) is contained in W. Then W=span(S).
Thanks for your reply vela.
I get what you mean. You are saying if A is a subset of B and B is a subset of A, then A=B.
Here is what I got so far:
let S={[tex]\lambda_{1},\lambda_{2}...\lambda_{n}[/tex]}
then, [tex]A1\lambda_{1},A2\lambda_{2}...An\lambda_{n}[/tex] E W1,W2,...Wm. (Closure under multiplication by a scalar.)
and so [tex]A1\lambda_{1}+A2\lambda_{2}+...+An\lambda_{n}[/tex] E W1,W2,...Wm. (Closure under vector addition.)
And so, span(S) E W1,W2...Wm
Thus, span(S) is contained in W, as W is the intersection of W1,W2...Wm.
How do I prove that W is contained in span(S)?
Anyway thanks for your help.
Consider the fact that span(S) is a subspace of V that contains S.
EDIT: I changed the wording in this post to say what I meant to say. Ignore what I had written here earlier.
OMG I GOT IT.
Since the span of S is a subspace of V, and W is the intersection of the subspaces in V that contains S, then obviously W E span{S}.
Thus, span{S} E W and W E span{S} and so W=span{S}.
Therefore, W is the set of finite linear combinations of S. =)
Thanks so much man. You are awesome =D.
