Is the Subset D={(x,y)| x≠0 and y≠0} an Open Set in R^2?
  • Thread starter Thread starter Deadward1994
The subset D={(x,y)| x≠0 and y≠0} is examined to determine if it is an open set in R^2. An open set requires that for every point in the set, there exists an open disk around that point entirely contained within the set. The discussion emphasizes the need to find a radius r for points in D, particularly focusing on points near (0,0) where the boundary exists. It is noted that as long as points are not at (0,0), a suitable radius can be found, confirming that D does not include its boundary points. Thus, D is classified as an open set in R^2.
Deadward1994
Show that the subset D={(x,y)| x≠0 and y≠0} is an open set in R^2
Open set: U is a subset of R^n. U is an open set when for every point X1, contained within U, there exists some open disk centered around X1 with radius r>0, that is completely contained within U. Or for simplicity's sake, a set U is open if it does not contain any of its boundary points.
I have an understanding of what makes up an open set and know why this set is open, but i have no idea as to how I am meant to prove this, graphically or analytically( ideal method).
Deadward1994 said:
Show that the subset D={f(x; y)| x≠0 and y≠0} is an open set in R^2
What does the notation f(x;y) mean?
Sorry about that, I miss quoted the question
First, tell us the definition of an open set.
So let (x, y) be a point in D. Can you find a radius r such that all points in the open ball of radius r around this point are in D?
First you may want to try drawing this, then proving it analytically. Note that for most points it's pretty trivial - the interesting case is for when (x, y) is close to (0, 0).
Also, presuming you can always find ##r## for arbitrary ##(x,y) ≠ (0,0)##, what happens at ##(0,0)## exactly?
Get reeeeeally close to ##0##. Can you always find an ##r## such that ##(0,0)## is not contained any neighborhood of your point?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
