Proving that AD in orthogonal projection
10 replies · 3K views
Petrus
Hello MHB,
I have hard to prove that AD, I did put on pic the formula for AD and my progress is at bottom.
Regards,
$$|\pi\rangle$$
Re: orthogonal projection
What is $\vec{u} \cdot \vec{v}$? I object to the notation $\cos(AC)$. You take the cosine of an angle, not the length of a side. Of which angle are you taking the cosine?
ops i meant $$\cos\theta*AC$$ Is my post unclear what I ask for?
Regards,
$$|\pi\rangle$$
Regards,
$$|\pi\rangle$$
No, the post is not unclear. I agree that what you're trying to prove is actually true. I was asking a Socratic question. You should write $AC \, \cos(\theta)$, so that's it's crystal clear what is inside the argument of the cosine, and what is not.
So, let me repeat the question: can you write out what $\vec{u} \cdot \vec{v}$ is?
$$u*v=|u||v|\cos\theta$$
Regards,
$$|\pi\rangle$$
Regards,
$$|\pi\rangle$$
Right. So why don't you use that to simplify the RHS, and see if you get the LHS? Then what could you do?
Hmm... One quest, could I get to that formula without knowing RHS ( I was more planing to learn how to get to that formula insted of 'memorize' it in exam)
Regards,
$$|\pi\rangle$$
Ah, I see. Well, here's how I would approach it. Start with a vector in the correct direction, $\vec{u}$. Normalize it by dividing by its length: $\vec{u}/|u|$. Now I have a unit vector (that is, a vector of length $1$), in the direction that I want. The goal is to compute $AD$, and multiply my unit vector by this length $AD$. Now, we know that
$$AD=AC \, \cos( \theta).$$
You'd like to write the RHS using the dot product. So, add in whatever is missing. Can you see how to finish?
those normalize formula I don't understand how we get it but I understand what it is. I understand exemple $$1=\gamma u$$ then $$\frac{1}{u}= \gamma$$ that is so far I understand about but how do they do after?
so I got:
$$\frac{|v|cos\theta}{|u|}*u$$ then multiplicate both side with |u| and use dot product to write the top as u*v?
is this correct?
Regards
$$|\pi\rangle$$
so I got:
is this correct?
Regards
$$|\pi\rangle$$
Basically correct, although I wouldn't multiply both sides by $|u|$, but I would multiply the top and bottom by $|u|$. Then you're done.
Thanks for the help and taking your time! Now I see how you got that formula :) Heh i meant top and bottom (Cool)
Regards,
$$|\pi\rangle$$
