Proving that for nilpotent A, A+I is invertible
  • Context: Graduate
  • Thread starter Thread starter Identity
The discussion centers on proving that if matrix A is nilpotent (i.e., Ak = 0 for some k > 0), then the matrix A + I is invertible. Participants explore the implications of A + I not being invertible, leading to a contradiction regarding the eigenvalues of A. The use of the geometric series expansion for (I + A)-1 is also discussed, emphasizing that nilpotency ensures convergence. Ultimately, the conclusion is that A + I is indeed invertible due to the properties of nilpotent matrices.
  • Understanding of nilpotent matrices and their properties
  • Familiarity with matrix eigenvalues and eigenvectors
  • Knowledge of matrix inversion and conditions for invertibility
  • Basic concepts of geometric series and convergence in the context of matrices
  • Study the properties of nilpotent matrices in linear algebra
  • Learn about matrix eigenvalues and their implications for invertibility
  • Explore the geometric series and its application to matrix functions
  • Investigate the relationship between nilpotent matrices and Jordan forms
Mathematicians, students of linear algebra, and anyone interested in advanced matrix theory and its applications in various fields such as engineering and computer science.
Identity
Suppose A is nilpotent, i.e. A^k=0, k>0. Show that A+I is invertible.
Here's my go at it... although I'm unsure about step marked with asterisks... is it ok? I'm not sure how to show that it's true for sure.
Contrapositive: Suppose A+I isn't invertible. Then (A+I)X =0 has a non-zero solution, say X = X_0.
Then
(A+I)X_0=0
AX_0+X_0=0
A^kX_0 +A^{k-1}X_0=0
If A^k=0 then A^{k-1}X_0=0... but X_0 is not a solution of A^{k-1}X=0.************
Hence, A must not nilpotent, QED
Thanks
Why?
Ok... I was bluffing. But I don't know how else to proceed!
I just assumed that since X_0 was the solution of one equation it couldn't solve another different equation.
It helps to gather some intuition from the one dimensional case here.
What is the inverse of (1+x) when x is small (x is a real number)?
If you mean multiplicative inverse isn't it
\frac{1}{1+x} = 1-x+x^2-...
Can this be used for matrices too...?
EDIT: Heh, I guess it can, thanks office_shredder
Of course you have to be worried about convergence, but in the nilpotent case that's not a big deal
I am a little slow, so could someone please humor me: just using 1/(1 + x) = 1 - x + x^2 - ...
and seeing x as A and 1 as I, isn't it apparent that this series converges since it is geometric and can be easily calculated? At what point does the nilpotency of A matter, and how can you use it in proof using the mentioned series?
For some integer power k, Ak = 0 (the zero matrix).
1/(1 + x) in the reals corresponds to (I + A)-1.
If A is just a real number and A=2, the series doesn't converge. The mere fact it is geometric isn't enough; you need your matrix to somehow be "small enough". What exactly small enough is is a lot less obvious for matrices than for real numbers, but if a matrix is nilpotent it qualifies
(A+I)v=0
Av=-v
A^2v=v
\dots
A^kv=(-)^{k+1}v=0
v=0
v=0 is the only vector in \textrm{Ker}(A+I)
A+I is invertible.
vigvig said:
Exp(X) = X+Id
Its not true. If X^k=0
e^X=Id+A+A^2/2+\dots A^{k-1}/(k-1)!
First, X^k = 0 is equivalent to being nilpotent. Second, you may want to replace all your As by Xs, but you are right. Sometimes you do get Exp(X)=X+id but not always. I forgot you could have something like a Heisenberg matrix where exponentiation puts ones on the diagonal but does alter one entry.
Suppose (I+A) is not invertible. Then there exists a vector v such that (I+A)v = 0.
Then v=-Av. Then -1 is an eigenvalue which is a contradiction since A is nilpotent i.e. all eigenvalues are zero.
  • · Replies 40 ·
  • · Replies 21 ·
