Proving that ∫₀^π √(1+sin x)dx = 4
19 replies · 3K views · last reply
i need to solve/prove the next two integrals:
[tex]\int\frac{dx}{u^2+u+4}[/tex]
and i need to show that:
[tex]\int_{0}^{\pi}\sqrt{1+sinx}dx=4[/tex]
the problem is that i have a clue to substitute u=sinx and then sin(pi)=0=sin0 so the integral should be equal zero, is it not?
ofcourse the integrand becomes: sqrt(1+u)/sqrt(1-u^2)
For the first you can use the method of partial fractions.
You're right about the second. With the given limits, the integral is equal to zero.
substitute u = 1 + sin x. Are you sure the integral is equal to 4, not -4?
But the plot (area) of the function sqrt(1+sin(x)) from 0 to pi seems to be non-zero!
neutrino, how would i use partail fractions here?
i mean i need to decompose u^2+u+4 into a product of terms, but i have complex roots here.
u^2+u+4= (u + 0.5)^2 + 15/4.
edit: too slow, the second integral should equal minus -4, I guess they're defining is it as area so you just need the modulus.
Not -4. I just put the function through the Integrator and substituted the values, and I got 4. This graph is completely above the x-axis.
Btw, you will need to know what the derivative of the inverse tangent is.
Oops, I'm missing/added a minus somewhere. Didn't have the common senese to think about the graph :).
If you let u= sin(x) then du= cos(x)dx so your integral will involve something like [itex]\frac{du}{cos(x)}[/itex] (with the cos(x) converted to u of course) but [itex]cos(\pi/2)= 0[/itex] so that is not a valid substitution.
You need to be careful about which square root you're using: The integrand should be:
[tex]\frac{\sqrt{1+u}}{\pm \sqrt{1-u^2}}[/tex]
The trick is that you'll be using one square root from [itex]x=0[/itex] to [itex]x=\frac{\pi}{2}[/itex] and the other root from [itex]x=\frac{\pi}{2}[/itex] to [itex]x=0[/itex].
