Proving the convergence of series
The discussion revolves around proving the convergence of a series defined as the sum of \(\frac{(n+1)(3^n)}{2^{2n}}\) from \(n=1\) to positive infinity. Participants are exploring methods such as the Comparison Test and Limiting Comparison Test, particularly in relation to geometric series and p-series.
  • Participants discuss splitting the series into two parts and consider the convergence of each part. There are inquiries about the nature of geometric series and how to apply comparison tests effectively. Some participants express confusion about specific terms and seek clarification on the definitions and properties of series.
The conversation is ongoing, with various participants offering insights and suggestions on how to approach the problem. Some have proposed specific values for comparison, while others are exploring the implications of those choices. There is a general sense of collaboration as participants work through the complexities of the problem.
Participants are grappling with the definitions and properties of geometric series and p-series, as well as the requirements for applying the Comparison Test. There is mention of needing to prove certain inequalities for large \(n\) and discussions about the limitations of their current methods.
Raymondyhq
Prove the convergence of this series using the Comparison Test/Limiting Comparison Test with the geometric series or p-series. The series is:
The sum of [(n+1)(3^n) / (2^(2n))] from n=1 to positive ∞
The question is also attached as a .png file
2. Homework Equations
The geometric series with a * r^n is known to:
  • converge if the absolute value of r is smaller than 1
  • diverge if the absolute value of r is greater or equal to 1
The p-series (1/n^p) is known to:
  • converge if p is greater than 1
  • divergent if otherwise
Please refer to this website for the definition of the Comparison Test and the Limiting Comparison Test:
This is as far as I got:
∑ [(n+1)(3^n) / 2^(2n)] can be split into two series,
∑ [n(3^n) / (4^n)] + ∑ [(3^n) / (4^n)]
The latter series is known to converge because it is a geometric series with r = 3/4
However, I am stuck trying to solve the first series.
Using the Ratio Test to determine whether the series converges or diverges is quite simple, and I have worked it out.
By the way, could anyone tell me how to make the formulas look more ... natural? Instead of using ^ and / as well as a ton of brackets.
Any help is appreciated!
Can you trap ##(n+1)(\dfrac{3}{4})^n## and a geometric series ##\sum q^n\,##?
Could you elaborate? I don't quite understand what you mean by ∑qn
What is a geometric series? You're requested to use one. So you need to know what it is, which of them converge and finally what comparison means. If you can answer all three questions correctly, you're almost there.
The first series can be written as ##\sum n (3/4)^n##. What can you say about this series by using the Comparison Test or Limit Comparison Test?
This is exactly what I am having trouble solving. I could try to move n into the brackets with 3/4.
∑n(3/4)n = ∑(n√n)n(3/4)n = ∑(n√n 3/4)n
Then I am stuck.
You have to find a quotient ##q## with ##(n+1)\left( \dfrac{3}{4} \right)^n < q^n##. Any ideas how to find a ##q\,##? Hint: find a quotient ##p## with ##(n+1) < p^n## first.
I am having trouble finding a p that satisfies pn>(n+1)
:cry:
:cry:
In this case the quotient would need to be ... greater than 1?
Well, ##p=2## would certainly do, for all ##n>2##.
Exactly. Now in the example with ##p=2## we will lose too much space, because we need ##p^n \cdot \left( \dfrac{3}{4} \right)^n < q^n < 1##.
This narrows it down, but there are still enough possibilities.
What about p = 11/10 ? pn would be greater than (n+1) if n is sufficiently large, and pn * (3/4)n = (33/40)n which would satisfy r < 1.
Yes, that would do. You still need to prove, that it gets larger than ##n+1## (binomial formula) for which (?) ##n## and sweep everything together for a formal proof.
I could set up the equation (11/10)n = n+1 but I would not be able to solve it without the aid of a graphing calculator. Using a graphing calculator, I found that for all x > 40, pn is greater than n+1. Thus, I would have proved that when n goes from 1 to positive infinity, the series (33/40)n > (n+1)(3/4)n.
Could you suggest a simpler method? In my Calculus 2 course, the use of the binomial formula was not mentioned.
Thanks!
Well, you have to explain why ##n+1 < \left(\dfrac{11}{10} \right)^n ## for large ##n\;[*]##. I find it easiest by using ##\left(\dfrac{11}{10} \right)^n = \left(1+\left( \dfrac{1}{10}\right) \right)^n=1+\binom{n}{1}\left(\dfrac{1}{10} \right)+\binom{n}{2}\left(\dfrac{1}{10} \right)^2+ \ldots + \left(\dfrac{1}{10} \right)^{11}## but you can as well proof that ##x \longmapsto (x+1)^{\frac{1}{x}}## is monotone decreasing with limit ##1##, or by induction that ##(n+1)^{\frac{1}{n}} > (n+2)^{\frac{1}{n+1}}## or rule out by another method, that it cannot increase for large ##n## at some point. Maybe it's even enough to simply say, that exponential behavior outnumbers polynomial behavior, or just take it for granted - I don't know. For a rigorous proof, we need ##(n+1) \cdot \left( \dfrac{3}{4} \right)^n {<}_{[*]} \left(\dfrac{11}{10} \right)^n \cdot \left( \dfrac{3}{4} \right)^n = \left( \dfrac{33}{40} \right)^n## and the value of ##\sum_{n \in \mathbb{N}} \left( \dfrac{33}{40} \right)^n##. Thus some argument for ##[*]## is needed, in my opinion.
Thanks!
Have you had the fact that
$$\lim_{x \to \infty} \frac{\ln (x)}{x} = 0 ?$$
If so, that means that for any fixed positive constant ##c = \ln(1+\alpha) ## (with ##\alpha > 0##) there is some ##N_{\alpha}## such that ##\ln(x) < c x## for ##x > N_{\alpha}##, hence ##n < e^{nc} = (1+\alpha)^n ## for ##n > N_{\alpha}##. Therefore, for ##0 < r < 1## we have ##n r^n < (r(1+\alpha))^n## for ##n > N_{\alpha}##. As long as you choose ##\alpha## so that ##(1+\alpha) r \equiv \rho < 1## your terms ##n r^n## are bounded above by a convergent geometric sequence ##\rho^n## for all ##n## beyond a certain point. For given ##r## and ##\rho \in (r,1)## you can figure out what values of ##\alpha## will work, then pick one such value and thus figure out what is ##N_{\alpha}##. However, for just proving the result you do not need to do any numerics; it is enough to know that certain things exist (and, in principle, could be found explicitly if need be).
